Glass on gm b body
Glass on gm b body
Does anybody know if door glass from a 67 lesaber will for in a 66 delta 88? There both two door hard tops.
Hey guys still hoping some one can help with glass interchange, I have a 66 delta 88 convertible, and I want to know if a driver's side door glass out of a 67 lesaber will fit it or not? Thanks for any help
Sorry I wanted to check this out for you this morning but had got delayed..anyway the door glasses are the same. I referenced back to my 1977 ppg auto glass book and it shows all the glass is identical for that year.1967 lasabre and wildcat 2dr hardtop is interchangeable with 1967 delmont 88, delta 88 and delta custom 2dr hardtop also...domestic doors #3766 passenger and # 3767 drivers side both have 3 holes in the glass. Hope this helps.
Sean..X glassman
Sean..X glassman
Ok..sorry I had to find an older book..1973 NAGS go back to 65-66.. It shows the 66-67 windshields are the same DW660 and vent glasses are the same DV 3405, 3406 higher # being drivers vent...door glasses have different #'s DD 3659-60 for 66 and DD 3766-67 for 67..as it shows both block sizes are the same 18x36, and the both have 3 holes in them.. The quarters are a different size between both years but the Backglasses are same size 30x52..66 is DB 3475 and 67 is DB3770..I'm thinking the 67 part number for doors and back glass supersedes the 66 being the same block size and each have 3 holes....quarter glass size for 66 is 16x28 part # DQ 3414-15 and 67 quarter size is 18x36 part # DQ3768-69..looks like the Door and quarter in 67 are the same size. Hope this helps.
Sean
Sean
That was a lot to digest
I believe I have a '66 88 or 98 convertible [which I believe you said your car is, though I see "hardtop" in your posting also] parts car that still has glass in it. Maybe. In case these other routes fail to produce.
Let me see if I can tabulate Sean's info to a quick chart easier to pick out what is needed:
66-67 vent glasses are the same DV3405 RH, DV3406 LH
66 Door DD3659 RH, DD3660 LH
67 Door DD3766 RH, DD3767 LH
Both block sizes are the same at 18x36, and both have 3 holes- I'm thinking the 67 part number for doors and back glass supersedes the 66 number, being the same block size and each having 3 holes
Back Glass 30x52
66 Back DB3475
67 Back DB3770
Rear quarters are a different size between both years
66 Rear Quarter DQ3414 RH, DQ3415 LH; size 16x28
67 Rear Quarter DQ3768 RH, DQ3769 LH; size 18x36
Back Glass 30x52
66 Back DB3475
67 Back DB3770
Well, thank YOU sir for providing that info!
I only formatted it a little with CR's and white space to make it easy to pick out the parts future readers might need- and used full PN's so text searches can find them. I aims to help.
Well thank you both for all the info. So it sounds from my understanding that 67 and 66 door glass is different. That all 67 for 67 but not all of the glass for 67 doesn't for 66 is this corect?
Buick '66 LeSabre & Wildcat conv.
Buick '66 Electra 2Dr.
Cadillac '66 conv.
Chev. Pass. '66 conv.
Olds '66 Starfire & 98 2Dr. H.T.
Olds '66 conv.
Pontiac '66 conv. & Grand Prix 2Dr. H.T.
The '67 Buick LeSabre (& Wildcat) shows 2991 for the 2Dr, H.T. and 2994 for the conv., hence, they probably will not interchange with the '66 Olds.
Appreciate all that you guys posted looks like I am **** out of luck on this deal. It was a free door glass so no big lost except still in need of drivers door glass.
bigdooly
December 17th, 2015 07:03 PM
carmax
October 11th, 2011 08:38 PM
