Fuel return line 72 Cutlass
Old Jan 19, 2023 | 09:12 PM
covers1972's Avatar
My 72 has no fuel return line. I'm swapping the 350 for a 455 this spring. My car does not have a fuel return line now. I'm obviously putting in a new fuel pump and have a new tank and sending unit the is set up for the return line. On to the question...Is the return line beneficial enough to make it worth the effort to put a line in? I'd fab it myself with the copper nickel lines, they're way more forgiving than steel.
Old Jan 20, 2023 | 01:06 AM
fleming442's Avatar
Yes, 100% beneficial. It keeps the fuel cooler through constant circulation which makes more horsepower and helps prevent vapor lock in high temperatures.
Old Jan 20, 2023 | 06:13 AM
The return line is not mandatory with the engine swap but as Fleming noted, it's definitely a good idea. The cat urine that passes for gasoline today could definitely use it.
Old Jan 20, 2023 | 07:43 AM
covers1972's Avatar
That answers that. I knew of the vapor lock thing, but didn't consider the cooler fuel HP benefit. Thank you.
Old Jan 20, 2023 | 07:47 AM
covers1972's Avatar
Lol cat urine. My daughter has a couple cats... hmm the money saving possibilities. Now I can order the proper pump... one set up for the return. Thank you.
Old Jan 20, 2023 | 08:31 AM
fleming442's Avatar
Yup, dyno proven on Engine Masters....
Remember the old school cool cans? They worked!
Old Jan 20, 2023 | 01:08 PM
Not to mention the hot restart issues.
Bmoskal
Sep 19, 2018 10:15 AM
71cutlass350
Mar 27, 2018 09:21 PM
Oldssupreme
Jan 19, 2016 05:17 PM
TwoCalibers
Nov 29, 2014 11:51 AM
My72Cutlass
Jun 13, 2013 07:10 AM
