fuel line
Assuming you have an original (or equivalent) fuel pump, the line from a 1972 442/Cutlass with 455 will work. Be aware that many aftermarket fuel pumps have the outlet port at a different angle that stock, which may cause a problem using a pre-bent line. These lines are not that expensive from the usual tube vendors.
You wouldn't have a name or a link would you?
Del70
Dec 7, 2025 02:13 AM
