fuel hose issue
fuel hose issue
I know that this is a stupid question, but I have never really had to mess with one, so fire away.
The hose that runs from my fuel pump to the metal fuel line has some dry rot and needs to be replaced. When I pull the hose off of the line to do this will gas constantly flow out, or does it need the car running and the fuel pump operating for that to happen. If it is going to flow, what is the easiest way to plug the metal line while getting the replacement hose?
If it is the inlet to the pump, yes fuel will flow out as its gravity fed from the tank which is higher than the pump. Although the pressure side of the pump is normally steel there are some occasions where it has been replaced and there will be some fuel that runs out of it.
What I normally do for fuel lines is to have the hose precut and clamps ready to install and try to reassemble as quick as I can to minimize the fuel spill.
Do you know what size for the hose? That was the main reason that I was thinking about plugging the metal fuel line first. I figured that after pulling the hose, I would run over to the local parts store to make sure that I got the correct one.
The hose will most likely be 3/8... Cut the hose about one inch from the end of the steel tube, push in a 3/8 bolt and hold in place with a clamp... This should minimize any fuel leakage until you return with the new hose... If by chance you have a 5/16 line, repeat the process with a 5/16 bolt...
Take a pair of long nose vise grips and pinch the hose right at the steel line. Then cut it off and take it to the parts store and buy the matching size. If you don't have any long nose vise grips use hookem horns plan.
Use low pressure air to clear the from the carb back to the tank....10psi will work.
Then replace all of your rubber hose with fuel injection hose.
It has a liner that is impervious to ethanol, and lasts much longer than regular hose.
When replacing the fuel hoses which attach to the short segments of hard line which run through the frame, make sure you slide the hoses far enough onto the hard lines to protect the hard lines from the edges of the openings in the frame. If you allow the hard lines to rub directly against the frame, they will eventually wear through. Ask me how I know. This is shown in the Assembly Manual (and maybe the Chassis Service Manual?).
Check the hoses at the tank also, they are often neglected as they are out-of-sight. If the line at the pump is bad these probably are also. For changing the front line use the tips suggested and if you can park on a hill nose-up to help the situation.
If you change the hoses at the tank be careful as the fuel may leak onto you. Don't use any old style HOT drop/trouble lights, gasoline on a hot light bulb...not good!
The easiest solution is to drive it almost empty, pull the hose, and drain into a short, wide, tote, if you want no mess it all. Corvettes suck for doing this, their tank is way up there above the rear end.
Fixed...with no leakage! I put front end up the night before on some stands. This morning when I pulled off the old, dry rotted line, it was dry as a bone. No gas at all coming out.
I like 10 minute fixes where no problems come up.
By the way, it was a 3/8 inch hose.
Thanks again.
Thanks again.
Dead Reckon
July 14th, 2014 02:35 PM
