front end alignment specs 1975 delta
Old Jul 24, 2013 | 06:08 AM
richard1437's Avatar
I am looking for the alignment specs for my 1975 olds delta 88 royal conv, with 225/75/15 tires, had the front end checked all is ok, It is wearing the outside edge of the tires a little, so i would like to get it aligned, but would like to know the specs, to make sure the shop i am going to has the right specs
thanks in advance
Richard
Old Jul 24, 2013 | 06:22 AM
The wear on your tires can be attributed to camber or excessive toe in settings. I like these settings:
0-0.5 Negative Camber
3.5 TO 4.5 Positive Caster or as much as you can get with a .5 difference on the passenger side for road crown.
1/16-1/8 Toe-In
Old Jul 24, 2013 | 06:57 AM
jaunty75's Avatar
I had new tires, 235/75R15, put on my '73 Custom Cruiser back in 2010, and I had the same shop do an alignment. They had the specs. I didn't have to provide them. Since then I've put about 5,000 miles on the tires and actually rotated them myself a couple of months ago. They showed no abnormal signs of wear at all.
I would think that any alignment shop worth its salt would be able to locate the specs for your car, and, in fact, I'm not sure I would trust my car to a shop that basically needed me to give them the info to do their job.
The most important thing you can do to assure proper wear is to keep the tires inflated to the correct pressure.
Old Jul 24, 2013 | 06:58 AM
alignment
Thanks Oldcutlass
for your help, i will use those #,s when i take it in for the alignment, just want to make sure the shop is correct,
Richard
Old Jul 24, 2013 | 07:15 AM
In my recent experiences the newer alignment machines pre-programmed specs don't go that far back but the settings for the older cars did not vary much and a good front end guy knows what works. Remember settings are just a guide and vary based on parts condition, size of tires, etc. The test drive is the final test, just make sure it drives right.
Old Aug 1, 2013 | 07:10 AM
I took the car in ,, and the alignment was fine, program settings were right on, the car and the computer
thanks again
Richard
Old Aug 1, 2013 | 07:30 AM
No problem, glad it worked out. How much caster were they able to get?
Old Aug 1, 2013 | 07:47 AM
Not sure now, what the numbers were, the guy that did , was an old car buff , the dealer called in to do it,
This was actually done at a Chrysler dealer, the car goes down the road fine
thanks
NJ442
Nov 18, 2013 05:33 PM
NJ442
Suspension & Handling
Nov 18, 2013 09:19 AM
Don R.
May 11, 2011 06:57 PM
Caprice89
Apr 18, 2011 01:01 PM
60Olds98
Ninety-Eight
Aug 22, 2008 05:30 PM
