Frame dimensions 69-442
Does anyone have or have a source for the frame dimensions for a 69-442?
The service manual only has the front frame horn width dimension and I can't seem to find anything in the assembly manual.
The inspector's manual lists an id # as BE (3943331).
I am assuming that the frame is an A.O. Smith frame but will have to find the stamped number an the frame to confirm this.
Any help much appreciated. Thanks.
Peter, I bought it through a vendor on Ebay. If you search Ebay you'll find a few vendors. Here is one I found with a quick search.
These are crash data sheets used by auto body shops to check frames for dimensions.
http://www.ebay.com/itm/1970-Oldsmob...d31030&vxp=mtr
WWI Flying Ace
October 20th, 2008 08:55 AM
