Fitech
Old May 29, 2016 | 03:24 PM
richkidd24's Avatar
Fitech
Has anybody installed the fitech efi trying to see any pics
Old May 31, 2016 | 03:31 AM
fleming442's Avatar
What do you need pictures of? It's a pretty simple system.
Old May 31, 2016 | 08:50 AM
TripDeuces's Avatar
Saw it installed on TV the other day, lol. Pretty self-contained overall.
When they swapped to a carb it made more power though.
Old May 31, 2016 | 04:32 PM
Oldracerjones's Avatar
I just finished installing the FAST EFI 2.0 and it was amazingly easy. The hard part was updating the fuel system and ignition. It started first time and ran.
Old May 31, 2016 | 04:52 PM
richkidd24's Avatar
just trying to see the overall install where ppl are mounting the fuel center
Old Jun 1, 2016 | 07:48 AM
If you mean fuel sender it should be as close to the tank as possible.
Old Jun 1, 2016 | 10:30 AM
1970-W30's Avatar
Here's where I mounted the "fuel command center" on my 65 F85. I ran the vent line back to the tank. Unfortunately I'm still waiting for the TBI unit part which is on backorder till 6/15. Chose the FITECH unit over the FAST system because two of my friends that have the Fast units suffered 3 computer failures between the two of them. That and the fact the Fitech uses many standard GM components in their units and is quite a bit cheaper.
Old Jun 1, 2016 | 06:25 PM
richkidd24's Avatar
thanks what are u going to do with your temperature sending unit i want to keep my gauges but you have to run the units sending unit
Old Jun 1, 2016 | 06:34 PM
midrange's Avatar
Shaking out the cobwebs..
I wish I could show you my install, but I haven't been able to do it yet.
Between an above ground pool needing a complete releveling, a strained back due to reworking the landscaping around the pool, followed up by a pretty rough case of plantar fasciits, I'm having a dandy of a spring/early summer.
I didn't go with the fuel command center, as I have been following several threads on other car forums, where the system wasn't working properly.
Several cases were the stock mechanical pump couldn't supply enough fuel to the CC.
Others were having problems with the CC not venting back to the tank properly. Fuel was plugging up the vent line and bogging down the inner fuel pump.
I'm going with a homemade version of a Vaporworx in-tank fuel system, using a 2010 Camaro pump and custom made tank tray.
I'll post pics of the tank when I get them off my phone.
Old Jun 1, 2016 | 06:36 PM
midrange's Avatar
There should be another port in the intake where you can install the FiTech sender.
Old Jun 1, 2016 | 06:41 PM
richkidd24's Avatar
thanks anything will help
Old Jun 1, 2016 | 06:59 PM
midrange's Avatar
Here's the tank that my brother built for me.
The last pic is of another one he had done a year ago. I don't have any close ups of mine.
I'm also using a combination of 3/8 stainless lines and PTFE braided lines.
Cant' wait to get started on this.....
*my brother didn't weld them up, it was a friend of his that hooked him up.
Old Jun 1, 2016 | 07:02 PM
richkidd24's Avatar
his work is really good
Old Jun 1, 2016 | 07:09 PM
midrange's Avatar
I need to add a disclaimer, he didn't do the welding. He can weld, but not the TIG that was needed on them.
Old Jun 3, 2016 | 02:53 PM
tmaleck's Avatar
I don't have many pics yet, as I am still in process. I'm running an Edelbrock intake, so it has the extra spot for the second temp unit.
I chose the Spectre GM37BFI in tank pump for fuel delivery. I too have read only bad things about the fuel 'command' center. You can use your original steel line for the return or a few other options. I should have mine running a few weeks, I'll post picks and review then.
Tim
