a few questions
Old Aug 21, 2010 | 06:41 PM
young olds's Avatar
a few questions
1. can pluggin the pcv make the crank case pressure push oil out from between the block and intake?
2. ive been having a backfire through the carb and have read that this usually has something to do with timing. but i havent figured out what specifficly. i have tried a different carb and the prblem remained.
3. if anyone would be willing to come by and help me out it would be greatly appreciated, im usually pretty good with doing stuff myself but no. 2 is kicking my butt. pm me on this one.
Old Aug 21, 2010 | 09:04 PM
rocketraider's Avatar
Oldsdruid
1) Yes. Engine has to have a crankcase air intake and a way to evacuate the crankcase. Old way was to use a road draft tube to pull vapors out. PCV does the same thing but sucks them back into the intake for reburn. A plugged PCV system, intentional or otherwise, will definitely cause pressurized oil vapor to seep out of any crack it can find.
2) Does the car still have points ignition? If it does, 1) check inside the distributor cap for cracking or carbon tracking and 2) replace the ignition condenser.
If you're that far into it might as well change points and rotor too.
Remember to set points dwell first, then timing. 30 degrees dwell on an Olds engine, timing is year/model specific.
Old Aug 21, 2010 | 09:34 PM
young olds's Avatar
no, i have hei
MDC
Dec 16, 2008 05:13 AM
MeanGrnGt
Jul 15, 2008 08:00 PM
72Cutlass
Oct 26, 2007 05:45 PM
70OAI4speed
Jan 7, 2007 10:17 AM
