Fan shroud
Old Dec 12, 2011 | 11:53 AM
Dokks74's Avatar
Fan shroud
In another thread I asked several questions concerning dual electric cooling fans. If I decide to go with original stuff, what shroud will fit my 74 Omega, and will a big block chevy 5-bladed fan have the same bolt pattern? Thanks in advance. The Omega currently has a original 350 in it. And I just want to say thanks for all the quick responses my questions here generate. It's much appreciated.
Old Dec 12, 2011 | 12:44 PM
I just tried looking for 74 Omega fan shrouds. Did they even come with fan shrouds? I could only find parts for older Nova's - I know they are sister cars. These are pretty hard to find aren't they? Have you posted anything on other forums looking for parts? I honestly don't know if a 73/4/5/6 Cutlass shroud would work or not. I think you would need measurements on the rad support - water pump to find out.
Old Dec 12, 2011 | 01:22 PM
Rickman48's Avatar
I believe a Nova shroud will work, and I'd use a clutch fan - a 5 bladed fan will make it sound like a garbage truck, and cost 35 - 40 H.P.!!
Old Dec 12, 2011 | 02:01 PM
I'm not sure I understand this. My Cutlass has a 4 blade without the fan clutch. Are you suggesting that I'd get that I'd see a hughe hp jump just by changing the fan arrangement? I don't get it. Can you explain? thx
Old Dec 12, 2011 | 04:02 PM
Rickman48's Avatar
Car Craft did a 'Dyno test' on fans, a few years back, when the exploding flex fans came out.
Showed a direct-driven fan, [any] takes big H.P. to turn, compared to a properly functioning stock clutch fan!
And a shroud makes a huge difference!
Old Dec 12, 2011 | 04:08 PM
thx for the heads up. I was planning to install both next summer so your info took me quite by surprise. I didn't realize dd fan took that much power. Is this a similar concept to the amount of hp needed for an airplane propeller in terms of hp? Do you still have the link to the website or know where I can find it?
Old Dec 12, 2011 | 04:14 PM
Rickman48's Avatar
That's why it sounds like a garbage truck!
I'm not even sure it was CC - I had 5 subscriptions back then, but you could google it!
shamusj
Jan 13, 2015 05:44 AM
rmoths
Dec 21, 2013 11:03 AM
KZ442
Nov 9, 2010 05:01 AM
hammerit
Feb 24, 2007 08:06 AM
