Fan Shroad
Year and model is important. In a 66-67 the shroud rests on two brackets that are only on cars that came with a shroud (so if not you need to find those) two bolts like the ones that hold down the upper radiator hold down go through the shroud and into the brackets these are easy to get to if the top radiator hold down is off. The upper two bolts for the shroud go through the two holes in the top radiator hold down (holes are there even if the car did not come with a shroud) same type of bolts half inch head like what holds the radiator top plate down. That is it.
I will attach a few pictures for a 66-67.
Hope this helps
Let us know what year and model
Larry
lemoldsnut@aol.com
Hope this helps
Larry
lemoldsnut@aol.com
Here are pictures of the lower shroud mounting brackets, the top hold down plate with the bolts in it, and one of the hold down bolt inside the shroud to the lower brackets and one of the top mount front the engine view.
Hope this helps
Larry
Hope this helps
Larry
