Fan Clutch
Old Feb 22, 2010 | 01:24 PM
oldsonharmont's Avatar
Fan Clutch
How can you tell if a fan clutch has gone bad? (no Far Side references please) I spotted some oil leaked between the shaft and the clutch, but can you tell anything by just spinning it? Mine spins freely when it's parked, shouldn't there be some effort there?
Or does the engine have to be warmed up first? Thanks as usual for the replies. -Mike
Old Feb 22, 2010 | 01:38 PM
442Harv's Avatar
You should be able to turn by hand but not spin easy. Start the car also, and have someone shut it off, and see how much it spins when off, if a lot it is bad.
Old Feb 22, 2010 | 01:43 PM
70 cutlass s's Avatar
With engine off grab hold of the fan rock the fan back and forth for play. That's how you check for bearing wear. It should be able to turn freely. When you rotate it by hand. If you see oil that looks like its coming from the clutch fan shaft then it needs to be replaced.
Old Feb 23, 2010 | 04:49 AM
71rocket's Avatar
car nut farmer
Yep, oil is a good sign it's time to replace.
Old Feb 23, 2010 | 07:23 AM
dc2x4drvr's Avatar
The max lateral movement at the fan tip is 3/16", according to the the Chassis Manual.
Old Feb 23, 2010 | 09:42 AM
Lady72nRob71's Avatar
My old fan clutch passed the above tests. What is did not do was engage when it should...
When you first start the car cold, the fan should give a distict roar for 5-30 seconds while its internal silicon fluid is dispersed.
Also, when the car is running hot, at idle, it should cycle on and off depending on radiator temperature.
After a long hot drive, park the car and keep it idling. Open the hood and listen for the roar. When you hear it, stand at the left front fender, poke your head under the hood and look at the fan. Your hair will be blowing wildly and it will be loud. As the radiator cools, the fan will start freewheeling (and quiet down) until it gets hot again.
An infrared thermometer can help verifying engine and radiator temperatures. The fan should engage around 195* radiator temps or so.
Old Feb 23, 2010 | 06:44 PM
So do you recommend a standard fan clutch or should I go heavy duty
for those Arizona summers?
Old Feb 23, 2010 | 06:49 PM
I would put a heavy duty one on it. Just a few more dollars.
Old Feb 23, 2010 | 06:52 PM
How about for us guys without hair. I guess I need a wig for the next time. I check a clutch fan.
Sorry Rob I couldn't help myself.
Old Feb 23, 2010 | 07:10 PM
If taking your cap off won't work to expose the test hairs, then just turn and face the front of the car, take your shirt off, raise your right arm, and......
Old Feb 23, 2010 | 07:25 PM
rtpassini's Avatar
is it necesasary to use the fan clutch. can you just use a flex lite fan?
Old Feb 24, 2010 | 12:38 AM
I tried a couple of those flex fans back in the 70's on some 455 Buicks.
They sure made a lot of noise and the motors didn't seem to run any cooler.
Old Feb 24, 2010 | 01:40 AM
svnt442's Avatar
Not only that, but they have this bad tendency to come apart at the wrong time (any time for that matter) and do mondo damage to under hood items like the radiator, hoses, that nice $3000 OAI hood.....you know...nothing too crazy.
Old Feb 24, 2010 | 02:26 AM
Bluevista's Avatar
Registered
Before I raised my arm to test for the correct wild hair movement would I have to take the dreadlocks and cornrows out first if I were a european women?
Could just wear shorts and stand on the fender?
Real carpenters keep a special hair in their wallet.
When a piece is just a hair big or small you need something to measure how much you have to cut off or add. Also need one to demonstrate at the bar how close you got, or didn't, holding your thumb and index finger slightly apart to show just doesn't have enough visual impact and is hard to see.
All guys specially procured hairs are different so you have to synchronize hairs with the crew before you start work in the morning to avoid discrepancies.
I've never worked with female carpenters?
They sure wouldn't need to carry any of those very special hairs in their wallet?
All the single guys at work with no luck would want to be borrowing one.
Last edited by Bluevista; Feb 24, 2010 at 02:36 AM. Reason: Deleted tasteless comment by Redgoat.
Old Feb 24, 2010 | 05:21 AM
They also put extra strain on the water pump bearings, causing them to fail sooner.
I would just stick with a clutch fan for street use.
Blue, I am gonna have to keep my comments to myself this time...
Old Feb 24, 2010 | 05:24 AM
x2 Flex fans look good hanging on a wall.
Old Feb 24, 2010 | 11:09 AM
Funny but true, I sold one to a buddy and it's been hanging in his garage for 25 years. I guess he's the sentimental type.
Old Feb 24, 2010 | 11:34 AM
cutlassgal's Avatar
Cutlass Lover
....Blue, I am gonna have to keep my comments to myself this time...
Yep... me too! LOL!!!
Old Feb 24, 2010 | 12:46 PM
mugzilla's Avatar
is Fast Enough ...
Cut the line ... Or leave it ... I worked for a carpenter and he did not want me to ask him anything ...
so I shut up and learned a lot ...
RandyS
Jul 6, 2021 07:45 PM
47 Convertible
Apr 3, 2014 07:56 AM
RandyS
Mar 8, 2014 05:07 AM
agtw31
Jun 23, 2009 01:39 PM
esisson
May 20, 2008 12:09 PM
