factory 8 track
Old Jul 10, 2017 | 12:07 PM
cwebb1020's Avatar
factory 8 track
Can it bw hooked up to a Factory am radio ??
Old Jul 10, 2017 | 12:15 PM
The factory 8 track ONLY connects to the factory AM/FM stereo. This is not a conventional system that has RCA connectors for an aux input. It's a dedicated design.
Old Jul 10, 2017 | 12:48 PM
rand5204's Avatar
Joe,
Does that mean it only works with the system using the multiplexer or any AM/FM radio
Old Jul 10, 2017 | 12:57 PM
Originally Posted by rand5204
Joe,
I though the statement "ONLY works with the factory AM/FM stereo" was pretty clear...
Old Jul 10, 2017 | 01:03 PM
I will add, however, that the factory 8 track CAN be used as a stand-alone if you are willing to modify the wiring. The 8 track has it's own amp built in. While it plugs into the factory stereo wiring it really interrupts speaker wires, switching the speakers from the stereo radio output to the 8 track output.
Old Jul 10, 2017 | 01:38 PM
My442's Avatar
Nope.
My previous 70 442 had an 8 track with an AM radio. Rear speaker too.
It is on the build sheet.
Old Jul 10, 2017 | 02:21 PM
Originally Posted by My442
Nope.
You are correct, my apologies. I was looking at an earlier year. The 1970 SPECS booklet clearly shows the 8 track available with U58 (AM/FM stereo) or U63 (Deluxe Pushbutton Radio). With U63, the 8 track included the rear speaker option, since this was required for the stereo 8 track. As I mentioned above, the 8 track has it's own amps and doesn't use the ones in the radio.
Old Jul 10, 2017 | 02:24 PM
rcorrigan5's Avatar
Randy C.
A factory 8-track will work with any factory radio as long as the radio is rear-speaker equipped. Or, at least that has been my experience with the '68 and '69 model years. A multi-plex unit is not necessary. The stereo sound comes from the 8-track unit.
Randy C.
Old Jul 11, 2017 | 04:59 AM
rand5204's Avatar
My442
Thanks. You beat me to it. Joe's response was just snarky enough that it pushed me to go the Wild About Cars website and pull up the 442 Order Sheet published there. Just like the salesmans guide Joe posted it shows the 8 track as available with the deluxe radio.
swapmeetdog
Feb 23, 2014 03:48 PM
Olds442redberet
Sep 17, 2013 07:20 AM
Vistabrat72
Feb 24, 2013 02:19 PM
mmurphy77
Jan 9, 2011 10:58 PM
boondocker
Jan 4, 2010 11:11 AM
