Exhaust bolts, any better than the others
I'm not going to make Cool April Nights again this year(about 2000 entry car show) because my exhaust manifold bolts gave it up again ,opposite side this time.My damn car sounds like a John Deer tractor.![Mad](https://classicoldsmobile.com/forums/images/smilies/mad.gif)
Are there any bolts that work better than others ,maybe stainless. I think we used # 8 harden bolts last time. This is on my 55...Tedd
![Frown](https://classicoldsmobile.com/forums/images/smilies/frown.gif)
If you remove the remaining bolts, can you use a die grinder on the broken ones to get the manifold off and there should be some bolt left to get them out. I've reused manifold bolts and never had tehm snap off, you think they might have been over torqued?
Anything is possible, the build on this car would go by pitifully slow one or two weeks then the next week parts would come in and three or four of us would put in a couple 12 14 hour days often doing work in relays. Plus it was 12 years ago, hard for a old man to remember.
Sorry, but I just broke out laughing and have to correct this. "Tinsel" is what you put on your Christmas tree to make it look like icicles are hanging off of it.
When talking strength of metals, or anything else, being stressed in tension, it's tensile strength.
Thanks for the replies/ suggesting, still haven't got it tore down ,Just found out at least two bolts/studs are missing but a small punch put into the hole stops at where the head starts.
This may take a while kinda booked up with health issues now.....Tedd
If you have broken that many, it sounds like either overly torqued, or NON-original crappy material. Used FACTORY fasteners might be preferable to new crappy fasteners. I have twisted off MANY an exhaust bolt, but this is in working on exceedingly crusty MI parts cars, and motors salvaged from the river [apparently].
Go with OEM fasteners or SS.
Either way, use plenty of ANTI SIEZE on them. Avoid future grief.
http://www.amazon.com/Permatex-80078.../dp/B000AAJTXY
gearheads78
February 20th, 2012 05:07 PM
slowolds
June 8th, 2010 05:35 PM
craftsmen22
September 25th, 2008 01:13 PM
