Exhaust assembly paste
I will be replacing my entire system with a factory correct system and I'm trying to find assembly paste and it's proving harder than I thought. The factory used a paste that eased the assembly and 'sealed' the joints. I can't find it anywhere locally. AFAIK it's not the same as Muffler repair stuff that cures rock hard.
Just use some "Anti-Seize" or Nevr-Seize" (different manufacturers).
The copper Aviation stuff is the cat's pajamas.
ps: Don't use too much, though, and don't use it on the nuts, or your exhaust system will fall off your car. Ask me how I know.
Thanks guys! This is what Napa has is that what you were referring to?:
https://www.napaonline.com/Catalog/C...516_0282385798 or https://www.napaonline.com/Catalog/C...335_0006383754
It says it hardens with heat which I guess is ok once I have the system positioned and tightened.
I wouldn't use either one of those - they look like silicate sealers, which harden up like cement and are very brittle - normal engine vibrations will crack them up and shake them lose.
Why are you looking for a sealer anyway?
I use Nevr-Seize to keep the pipes somewhat disassemble-able in case of future problems, but I've never heard of anyone using sealers on new exhaust systems.
I agree I don't want muffler cement so I guess the anti-seize is the way to go. My main concern is ease of installation as struggling with tight fitting pipes can old real quick.
Seems strange to me, go to any auto parts store in the UK and they will have exhaust assembly paste on the shelf.
Maybe over there exhaust are normally fitted and welded into one piece?. Here exhausts normally come in sections and are clamped with U bolts, the paste is lightly spread round the connecting ends on assembly and seal up any distortions.
Roger.
Roger.
atkinsom
May 29th, 2013 06:39 PM
Bigd442
May 17th, 2013 12:28 PM
65OldsDelta88SuperRocket
October 27th, 2011 09:16 PM
