Estate sale heads
Estate sale heads
Hello everyone, I recently picked up a 455 motor at an estate sale. I bought it without knowing any details of the internals. The motor was built for a boat but I jumped on it and bought it anyways. My plan is to tell the intake, headers and other boat specific parts and throw it in an olds.
I was hoping you guys could help me identify the heads.(I’m relatively new to the hobby so be gentle lol)
Picture of whole motor
Looks like it was freshly rebuilt
Generic 409100, 80cc, G heads off a 1971 455. Should, could, may, might, can, ought to, quite possibly could have and maybe by chance came wtih the big valves having all that induction... or not. What are the numbers on the engine deck by the oil gauge sender?
Put a squirt of 30W in each cylinder and with the plugs out manually prime it through the distributor hole while rotating it by hand until you see oil from all push-rods.
G heads
Generic 409100, 80cc, G heads off a 1971 455. Should have the big valves. What are the numbers on the engine deck by the oil gauge sender?
Not all G heads are big valves.
https://classicoldsmobile.com/forums...as-wanted.html
Check with the guy in this thread - he is looking for a dual quad big block intake manifold.
No, there are numbers above the water pump to the left of the oil sender. I said could have big valves not will. Chances are real good with this induction system that it's not a small valve head. Only way to know is to pull a head. Might even have some custom porting.
I have a set of these heads on my 66. I chose to rebuild them over the C heads I had because after researching flow numbers I decided the advantage of the G heads hardened seats, outweighed the performance advantage the C heads might have. They were off of a Toro and were the large valve.
I have been toying with the idea of a retro look for my 66 and that tunnel ram would fill that bill nicely. if it is still available please send me a p.m.
Could vs should
Sorry partner but if you look at my 1st post where I quoted your original post you wrote SHOULD HAVE THE BIG VALVES, That is why I corrected your post. They MAY have the big valves but likely do not.
I will have to pull the heads and see who’s right and what’s what! either way I know I will be happy. I got the motor for a great price regardless of the valve size.
2blu442
November 22nd, 2014 04:59 PM
2blu442
March 1st, 2011 05:18 PM
2blu442
February 1st, 2010 08:03 PM
64 Jetstar
April 2nd, 2007 09:17 AM
