Epoxy Primer and lacqure Application
Old May 6, 2011 | 04:43 AM
Del70's Avatar
Need some help, share experience in with epoxy primer and lacquer top coat, thanks
1) If I apply Epoxy primer to a fender, bare metal, can I then apply lacquer top coat over the epoxy premier?.
2) If I apply epoxy primer, then primer assumed to lacquer primer to work the panel, can I apply it and then a lacquer top coat?
3) Can Epoxy primer be applied over well cured lacquer.
Old May 6, 2011 | 08:10 AM
chequenman's Avatar
Question
Where you gettin' all this lacquer product?? Top quality paint jobs done to-day are done in Water Borne products and Clear Coats.
If you are applying Epoxy Primers don't even think about useing Lacquer primers over top!!! The one primer flexes and the other doesn't.....
Old May 6, 2011 | 09:06 AM
Swede98's Avatar
Boat?
Hi I work as a boat mechanic and we use epoxy primer and topcoat on boats but I never heard someone who has used these things on a car I agree with the previous post.
Old May 6, 2011 | 10:38 AM
69442C's Avatar
Here is a PPG Refinish link for their Deltron products and this shows their DP Epoxy primers. Click on any of the TDS tabs next to any of the DP items and you will get the technical data sheet. Their information shows that DP Expoxy primer/sealer can be applied over lacquer finishes with a few precautions. It also shows that lacquer can be applied over the DP epoxy as a top coat.
With this being said, I too would question the desire to do so. Lacquer paints are not widely available and this is not the manner in which quality refinish work is done today. I believe there are some companies who offer Nitrocellulose Lacquer but these finishes don't hold up well and require a lot of maintenance. So unless there is an absolute requirement to use lacquer, I would use a more modern paint system. I think that rattle can paint is still available in lacquer so I would hope you aren't trying to refinish a car with rattle cans?
https://buyat.ppg.com/refinishProduc...c-04551702a5df
Old May 6, 2011 | 10:40 AM
69442C's Avatar
To clarify, when you go to the link I showed, click on the primers and surfacers tab to get to the DP products.
Old May 6, 2011 | 10:50 AM
Oldsmaniac's Avatar
I plan on using acrylic lacquer on my 67 442. It is easy to spray and dries very quick. This is great if you must spray outside.... it dries before the bugs can stick to it. It also gives era look. It is forgiving. Most quality high gloss jobs these days do not reflect the finish the car had when it rolled off the assembly line. The drawback is the cost...I believe for PPG lacquer it is 500 dollars a gallon.
Old May 7, 2011 | 06:48 PM
Run to Rund's Avatar
I used PPG DPLF gray primer (epoxy) and the PG guidance is to top coat within a week. I covered some 40 year old lacquer (inside trunk, etc.) with the primer. So the answers are yes, yes, and yes. And, I wanted to use acrylic lacquer with the original luster, not a plastic looking top coat.
Old May 8, 2011 | 09:27 AM
Swede98's Avatar
Today i learned something
dre
Body work
29
Jul 31, 2013 09:37 AM
Nasty455
Apr 23, 2013 01:25 PM
Porter858
Sep 18, 2012 08:51 PM
Seriousfun
Jul 27, 2012 12:25 PM
Del70
May 6, 2011 03:54 AM
