Engine swap for 65 Delta 88
Old May 28, 2016 | 10:50 AM
wildcatmom's Avatar
Does anyone know if a 71 350 Rocket will fit into a 65 Delta 88?
Any issues that might arise?
Old May 28, 2016 | 11:11 AM
Sure, it'll fit fine.
It'll have about half the power, but it'll fit.
Issues would involve the carburetor linkage if one is a 2bbl and the other is a 4bbl, and the exhaust pipes might need a little "adjustment" to meet the manifold outlets, but nothing insurmountable.
Put all front accessories from old engine onto new engine to maintain harmony. There is a chance that the '65 BB brackets, being fairly early, may not also have the proper holes for installation onto SBs, but I do not know this.
Old May 28, 2016 | 12:36 PM
Exhaust manifolds may be an issue. The manifolds from the 425 probably won't work, due to the taller deck height of that motor. You'll need the manifolds that were used on the 330 motor in the 65 Jetstar 88, or equivalents.
Of course, use the 2262/2263 motor mounts from the 425 on the 350, and bolt them to the front two of the three motor mount holes in the block.
deltaskelta
Nov 21, 2012 06:41 AM
Fastdelta88
Non-Olds Engines
Nov 4, 2012 08:45 AM
'69CutlassVert'
Aug 25, 2011 07:19 AM
oldsmobum
Jan 14, 2011 10:10 PM
whizkid88
Feb 26, 2009 08:18 PM
