Engine rebuild stand~big block
Old Oct 21, 2011 | 03:03 PM
steve e summer's Avatar
Having taken a mighty hiatus from v8's I built wheel standing VW air cooled's for a while. FUN! Anyway, nothing beats the whallop of a big block and I'm back with a vengeance (3 of 'em) What's your opinion on a reliable engine stand? I don't care about price, safety is a much bigger concern. You get pinned under a 2800ccVW engine and you'll be lucky too if all you have to do is holler for help to get it off. Obviously my needs are clear. Gentlemen, and Ladies...your thoughts please? Thanks, steve e
Old Oct 21, 2011 | 03:24 PM
I like the 4 wheel ones with the drip pan between the legs.800 lbs. + is good enough The wheel ones just don't have the stability IMHO
Old Oct 21, 2011 | 04:54 PM
DeltaPace77's Avatar
I built my current 455 on a four wheel job I got from Summit racing for less than $100 bucks. Dropped the motor right into the car from the stand, so means all bolt torquing was done on this. A geared handle job would be nice, but not exactly like I'm a shop using it every day.
Old Oct 21, 2011 | 05:32 PM
w-30dreamin's Avatar
71 & 72,now I want a 68
4 wheel unit,stay away from the 3 wheeled units.
Old Oct 21, 2011 | 06:36 PM
Vega's Avatar
My friend used a 3-wheel for his 454 rebuild. It worked. Not that it wasnt SKETCHY hahaha, but it worked. A 3-wheel also worked for my 455 tear down. But I would suggest something better if its available or if the budget allows
Old Oct 21, 2011 | 06:40 PM
Agree totally. I've got one sitting in the garage doing nothing right now.....It used to have a 455 sitting on it and there were no issues with the weight or stablilty.
Old Oct 21, 2011 | 08:31 PM
oldsonharmont's Avatar
The 4 wheel stands from Harbor Freight aren't bad for the money. I just added a little extra bracing to mine.
Old Oct 24, 2011 | 06:02 AM
kjr442's Avatar
Kjr442
engine stands
I have two,one is a three wheel that has had a engine on it for about 13 or 14 years now, no problem at all. The other is a four wheel, and it is good accept the square (hollow) adjusters at the block mounting area it not so good. I built my 455 using that one and part way through it was sagging.
Old Oct 24, 2011 | 07:55 AM
citcapp's Avatar
This is the one I suggest. Great stand good price and stable
http://www.harborfreight.com/2000-lb...and-67015.html
Old Oct 24, 2011 | 11:28 AM
Seff's Avatar
I made my own. Maybe not the most elegant solution, but I'm cheap.
Originally Posted by Seff
Engine stand! Made a minor error what with not allowing room for the crank, but that was soon remedied with the aforementioned angle grinder.
http://img27.imageshack.us/i/157xb.jpg/
http://img831.imageshack.us/i/158bn.jpg/
http://img215.imageshack.us/i/159ie.jpg/
http://img600.imageshack.us/i/160j.jpg/
Old Oct 24, 2011 | 11:39 AM
kjr442's Avatar
Kjr442
That looks real stout!
bocoogto
Aug 26, 2023 06:09 PM
ybicutty
Oct 12, 2012 05:11 AM
Olds92
Oct 25, 2010 09:05 AM
sklbndt
May 15, 2009 11:41 AM
cts-v
Jan 10, 2009 06:20 PM
