Engine paint
Old Jan 4, 2013 | 09:15 AM
The Bug Man's Avatar
Engine paint
I need a source / part # for the correct darker blue engine paint for a 71 442 / big block. Any help would be greatly appreciated! Thanks
Old Jan 4, 2013 | 11:47 AM
rcrac3r's Avatar
Fusicks or Napa is supposed to have the correct colours for Olds engines.
Old Jan 4, 2013 | 01:22 PM
71drolds's Avatar
i got mine from the parts place in aerosol cans. heres what it looked like. i think its spot on but im no expert.
Old Jan 4, 2013 | 01:26 PM
lemoldsnut's Avatar
Supercars Unlimited has a great color match. I advise when you paint the engine to use exhaust manifold paint first. That cast gray color that is ultra high temp. Use it as a primer and your engine will have the same cast gray color as a base. This will make the color go on much better and be uniform. Most engines after hot tank and rebuild are kind of multicolored and the end color is kind of funky as a result. I have done this on a few engines with great success.
__________________
Old Jan 6, 2013 | 09:36 PM
krooser's Avatar
Hot Rod Has Been
good stuff....
http://www.hirschauto.com/prodinfo.asp?number=EE-QUART
Old Jan 7, 2013 | 08:07 AM
JOHNNYOLDS442's Avatar
Olds Specialist LOL
i got mine from fusick
Jamesbo
Paint
Jun 13, 2020 09:02 PM
jensenracing77
Paint
Sep 10, 2014 02:33 PM
JpMotorsports
May 15, 2014 07:08 AM
dlmsavings1
Sep 3, 2013 09:01 AM
805cut
May 3, 2012 08:11 PM
