Engine miss with vacuum advance
69 400. Having an issue at 2-2500 rpm, engine starts to misfire. Runs nice and smooth with vacuum advance disconnected but once I connect it, it misses. Timing is advancing fine, will go up to 50 btdc or so. It’s just rough. Running pertronix now, but it did it with points and a different distributor. I’ve tried different coils plugs wires etc. but like I said it runs great with just mechanical advance, just doesn’t advance as far.
this is the lobe sensor type, mechanical is around 10* initial I’ll have to check how high it goes with just mechanical
Depends on which Q-Jet carburetor you have and to which inlet the vacuum hose is connected. Above the throttle plates is ported vacuum, below the throttle plates is manifold vacuum. My preference is full manifold vacuum.
On my car 50* advance was too much. I had a misfire so I made a limiter strap out of a piece of hacksaw blade that covered about half the slot in the in the vacuum advance can. I ended up with 11* vacuum advance and no misfire.
Put the advance on manifold vacuum. be prepared to have to reset the idle speed.
if it misfires only with advance functional, and it’s really going to 50 degrees, you most likely need to limit the amount of vacuum advance. You can easily fabricate a limited tab, crane cams use to provide one with their recurve kits
I bet if you limit the total timing to around 42-45 degrees it will run much better
Erson .477/ 290 dur. single pattern
If you put the limiter on the other end of the canister arm, it will accomplish the same thing but also increase the amount of vacuum it takes to get the advance to begin to move. That’s sometimes an advantage of the canister provides a lot of advance, and with a weak spring.
You just need to remember to reset the timing. Putting the limiter on the other side will increase the initial timing because the starting point of the advance has moved.
Check this out.
