Engine Issues
Old Apr 5, 2018 | 07:12 PM
Roque Kerstin Gomez's Avatar
Engine Issues
So I searched the forums and didn't find this one. First off, my engine is a rebuilt 350 Rocket. After it warms up going down the road then come to a stop at a light for example...sometimes when taking off, the engine sputters and actually dies. Trying to restart it, I have to pump the gas about 4-5 times and then it will start again and run "fine" to a degree. The hotter the ambient temperature outside the worse this affect is. The cooler the ambient temperature, like early morning, not too much of an issue. One question I do have though is do I have to run leaded fuel even though it has been rebuilt and could this maybe be the cause...or two, could it be air fuel mixture and possible timing. Thoughts, ideas, general knowledge of same issue? Thanks in advance.
Old Apr 5, 2018 | 09:35 PM
What carburetor do you have, and is the choke adjusted properly?
One = no and two = yes.
Old Apr 6, 2018 | 04:41 AM
redoldsman's Avatar
Proud Viet Nam Veteran
Where are you located that you can get leaded fuel?
Old Apr 6, 2018 | 05:20 AM
cherokeepeople's Avatar
exactly.leaded gas went out years ago.maybe he meant ethanol?if you have to pump 4 or 5 times i would look at the accelerator pump.this will fall on it's face from a stop.with engine off pull air cleaner off and grab throttle shaft an turn while looking down the throat.see if you get 2 good streams of gas.
Old Apr 6, 2018 | 07:13 AM
OldsAl's Avatar
Definitely sounding carburetor related. Did you do a proper rebuild of the carb as part of your rebuilt 350? Could be choke related, could the idle circuit/mixture. I would drive the car with the air cleaner off (plug open vacuum lines) and see what’s going on. For example when this happens is the choke plate wide open? Otherwise find a good knowledgeable rebuilder and send your carb off.
Old Apr 6, 2018 | 08:29 PM
Sampson's Avatar
Since it sounds like it is worse after the car warms up, and when the ambient temp is higher I suspect that it is vapor locking. Check the fuel line to make sure it is isolated from manifolds or heat. Make sure the fuel filter is not touching the intake. You did not mention if the carb or intake is stock, but some carburators need an insulator between the base and the intake manifold.
Old Apr 8, 2018 | 03:59 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
It could be rotted or cracked hoses on fuel lines. Of course it could be a plugged filter, dying fuel pump or a worn out or misadjusted carb as well.
Old Apr 12, 2018 | 05:41 PM
Sorry I didn't get back with you all right away. So you can buy lead additive for those wondering. But as far as the culprit goes... It was the cheap POS electric fuel pump that someone put. It is a Mr Gasket #12S. Heard of it? Well apparently it is rated as one of the worst. So looking at suggestions for a new one. The GPH needs to be 33/34 and run 4-7 PSI.
Old Apr 12, 2018 | 06:55 PM
Why not just put a stock mechanical back on it? They are virtually trouble free.
Old Apr 12, 2018 | 07:39 PM
jaunty75's Avatar
You can buy lead substitutes, not actual tetraethyllead that was what was originally the "lead" in leaded fuels.
Old Apr 13, 2018 | 05:40 AM
This product has actual lead in it.
http://www.wildbillscorvette.com/OctaneSupreme01a.htm
Old Apr 13, 2018 | 06:25 AM
What pistons were used in the rebuild? What carb? As said, a stock mechanical replacement fuel pump is the way to go.
Old Apr 13, 2018 | 07:13 AM
Rustbucket2's Avatar
VP racing fuel station can get leaded gas, at least the one in my town can.
Old Apr 13, 2018 | 07:31 AM
jaunty75's Avatar
The EPA banned the sale of leaded fuel for on-road vehicles effective January 1, 1996. Permitted uses are in aviation, racing, marine, and farm vehicles and machinery. Otherwise, it is illegal to put it in your car. Doesn't mean people won't do it, but it is illegal.
Old Apr 13, 2018 | 07:57 AM
jcdynamic88's Avatar
you didn't say where the electric pump is mounted but i believe they are better at pushing than pulling so it should be near the tank as opposed to being under the hood.they seem to last longer and perform better.
BlueBeast
May 14, 2015 03:51 PM
Fred Kiehl
Vista Cruiser & Wagons
Mar 11, 2014 01:04 AM
BEERN420
Jul 16, 2013 04:15 PM
Prsabordo
Sep 27, 2012 10:47 AM
Oldsproject
Jun 15, 2007 08:52 AM
