Engine break in
Old Apr 10, 2011 | 12:33 AM
1969cutlazz's Avatar
Engine break in
Can anyone tell me how long and what RPM I should run my rebuilt engine for to properly break it in? Its a 1969 Oldsmobile 350. Everything is new. Built pretty much to stock. New cam,lifters,crank, etc. Thanks, Eric
Old Apr 10, 2011 | 09:08 AM
Rule of thumb is once you get it started and timing close, run the engine at 2000-2500 RPM for about 20 minutes to break in the cam. Then drive for the first 500 miles relatively normally, but try to avoid long term constant RPM cruising. You want to vary the speed, including coasting, to load both sides of the rings.
Old Apr 10, 2011 | 10:06 AM
firefrost gold's Avatar
make sure you put in break in oil. I used joe gibbs break in oil. It was more money but I had no problems. I think comp cams sells some too.
Old Apr 10, 2011 | 11:22 AM
815Cutlass1972's Avatar
" Hoo yah "
If your close to Route 20 you should drive on it. It has different speed limits, hills, and down grades, so your not stuck at constant RPM. I just picked-up my car with freshly re-built engine from the Western Suburbs, and drove on Route 20 back home, which was about 50 miles. Now time to change the oil and filter. I used Brad Penn break-in oil, and will use Brad Penn 10W-30.
Old Apr 10, 2011 | 10:52 PM
Good idea. I drive RT20 to work everyday.
Old Apr 12, 2011 | 04:47 PM
Bayou Olds's Avatar
Make sure you have some zinc in the oil, either through additive or through the formula of the company's mix.
Old Apr 13, 2011 | 12:05 AM
Yes, I use Rotella oil cause diesel motor oil has better wear additives. I add ZDDP zinc additive to it as well.
scooter123
Apr 14, 2013 08:41 AM
Olds
Feb 12, 2012 01:34 PM
1970455sx
Nov 28, 2010 03:58 PM
68Tom
Oct 21, 2010 01:26 PM
tim72
Jul 12, 2010 12:00 AM
