Engine/4speed trans for a 65 delta 88
Old Dec 29, 2017 | 06:51 PM
RocketRonnie's Avatar
What came in a 1965 delta 88 convertible with a manual transmission?
Old Dec 29, 2017 | 07:12 PM
Oldsmaniac's Avatar
Very few manual trans Deltas were built even though the 3 speed colum shift manual trans was listed as standard equipment in 65. The 4speed Muncie with long tailshaft was the other manual trans as optional and these were very scarce as well. All 65 Deltas came with a 425 engine.
Old Dec 29, 2017 | 07:20 PM
I think i found one in a yard. Check this picture out, looks like a manual trans clutch to me, how about you
Old Dec 29, 2017 | 07:21 PM
Someone once told me that I should get a 66 and older muncie. Why's that. This if a muncie must be a strong trans to live behind a 425.
Old Dec 29, 2017 | 07:23 PM
cherokeepeople's Avatar
cant enlarge pic..
Old Dec 29, 2017 | 07:28 PM
I dont see a shifter on the hump though.
Old Dec 29, 2017 | 07:34 PM
Originally Posted by cherokeepeople
cant enlarge pic..
There you go
Old Dec 29, 2017 | 07:49 PM
steverw's Avatar
Looks like an automatic to me, large brake pedal and an emergency brake pedal, I don't see a clutch pedal. Also looks like PRNDSL just above the steering column. I don't see a floor shifter or a hole for one.
Old Dec 29, 2017 | 07:50 PM
Hey thanks Steve, your right. Would this be the switch pitch th400?
Old Dec 30, 2017 | 06:47 AM
If it's the original trans, it would be a long tail switch pitch TH400 - assuming this is a Delta and not a Jetstar 88. The J88 would have come with a 330 and Jetaway.
Old Dec 30, 2017 | 08:48 AM
Do you think it would be a bop pattern in 65?. Why is the 66 and 67 switch pitch more favored then the 65?. I would like to build a switch pitch in a 70's th400 case. I've seen the long detailed information on the 442 site that you helped with.
I hope you got my pm from a couple months ago too.
Old Dec 30, 2017 | 10:13 AM
I don't "think", I know it's a BOP trans.
News to me.
Other than the fact that the early trans case isn't machined for a speedo drive adapter, the cases are the same. Be aware that to convert a non-switch pitch TH400, you not only need to swap the front pump and converter, you also need to install a plug with an 0.040" orifice in the pressure port that feeds the pump.
I did and thanks. No biggie, however.
Old Dec 30, 2017 | 11:03 AM
Ok.I'm off to pull this trans. Should I pull the whole trans or take the parts included for the swap?
Old Dec 30, 2017 | 11:08 AM
You will need a slide hammer and threaded adapter to get the pump out. You also need to partly disassemble the valve body to feed the solenoid wire through to the pump for the switch pitch. Also, having the old case will show you where the plug has to be installed in the new case. I'd just pull the whole thing. You'll want the switch pitch converter, at least as a core to exchange for a rebuilt. I got my rebuilt converter from Fatsco.
70sx455
Jan 6, 2015 09:45 AM
Oldracerjones
Feb 1, 2014 06:05 PM
3g87xm
Jan 4, 2014 08:37 AM
z11375ss
Oct 18, 2008 07:35 PM
