Old May 23, 2015 | 05:59 PM
Sully69's Avatar
I sure hope you guys are not getting sick of me, but I need to talk to someone about an electrical issue. In a nut shell, the battery sparks when I try to connect it. Poss first, the neg, big spark. I disconnected everything one at a time. I even unscrewed the fuse block from the fire wall. The only thing that was connected was the starter. I even disconnected the purple to the "S" Terminal.
I am stumped. I need a real trouble shooter.
Thank you in advance. So close to fire her up.
Old May 23, 2015 | 06:37 PM
You may have pinched or the battery cable to the starter is touching ground.
Old May 23, 2015 | 09:04 PM
Sully69's Avatar
I was wondering about that. I had the starter rebuilt and I was wondering if they screwed something up.
Old May 23, 2015 | 09:24 PM
This is where being systematic come in: You have to keep reducing the system and isolating the parts until you find the one that's bad.
You're nearly there.
Old May 23, 2015 | 10:27 PM
Sully69's Avatar
That's what I thought.
I disconnected everything, I mean everything. I separated the fuse box from the firewall. The only thing was the starter wire. Brand new, 1 gauge, heat shrieked on both ends. If it was grounding out, when I connected the poss, that wire to the battery, it should spark.
jf857
Apr 28, 2006 07:24 AM
BOB W M
Apr 7, 2006 06:30 PM
PetChemMan
Dec 15, 2005 04:15 PM
86in
Feb 9, 2005 09:49 AM
NV WIDOW
Sep 1, 2004 04:34 AM
