Egge Vs. Supercars Unlimited
So basically it's came down to this, the only place I can find flat tops for my 350 bored .060 over are these two sources. I've read alot of mixed reviews about Egge in here but I really want some flats to improve my compression. Pros and cons anyone on either of these two places??
I thinking finding a new block would be easier. I have given them away and bare blocks can be had dirt cheap. Why are you stuck with .060. You could always pay a little extra and have custom pistons made.
Egge has been in business for a very long time, and is pretty much the company in the US for custom or unusual pistons.
I don't know about reviews, but I wouldn't think twice about buying from them.
Well I have the #5 heads with an increase in valve size and was milled .010 and also which has some the highest compression out of all the olds heads and using a .41 head gasket. I'm no mechanic so I'm just doing what I know so far... Any suggestions??
Dirty mechanic. Paid 1600 for a brand new remanufactured engine then the piston started slapping around 500miles. I have so much money tied up into this engine I didn't want to just start over. Didn't find out is was .060 over until after I pulled it to check the slapping noises smh
Yeah I've did alot of reading on them and seen how long they've been around. That's why I was interested in them. But then I read in here on some threads and some guys didn't talk too highly of them so I was kind of stuck in which route to take
Who knows what else was done wrong in there.
That's already been done. I've pulled it out and broke it down to just the bare block and took it to a machinist. Everything has been checked and is good to go. Now I'm trying to select pistons
I don't think there is anything wrong with Egge as a company or with buying from them. What you will find is their pistons are cast, and like all aftermarket cast pistons, they will be shorter than factory Pistons or aftermarket forged Pistons. This will severely impact your expected compression ratio unless you do block and/or head machining to compensate for the short Pistons.
If it's at the machinist, have them measure the depth of the pistons in the bores at TDC, and measure the piston height from the wrist pin, then mill another 0.020-0.030" from the heads, measure the CC volumes, then, based on all of this information, determine the best piston to use for your desired CR.
Egge used to be able to make up pistons to your specifications - I don't know whether they still do.
possibilities
Sonic check your block & bore it out to a larger size & run custom pistons.
Deck to block.
Mill the heads more.
All of the above.
Lots of options left.
I am not an engine builder but there are many on here.
Try PM to CutlassEFI (Mark) or others & get advice from them.
Deck to block.
All of the above.
I have Egge in our automatic Jetfire and no problems. I also know of a guy with egge flat tops in his 350 engine with no problems. I am not claiming that are great pistons but for the two applications I know of them they are just fine. Our Jetfire is 10.0 compression with 6.5 lbs of boost and I run it hard enough to boost at least one time every time I drive it.
If you don't mind me asking what is the difference between your pistons and Egges? I just want quality products in my car so no insulting intended at all. I just want everything done right while everything is broken down at the moment
All this means you can build an engine with "10.5:1" pistons and actually have a lot less than 10.5:1 compression ratio.
Also, the advertised CR on Oldsmobile pistons assumes the use of the factory steel shim head gasket. Changing to a thicker FelPro blue gasket (as an example) results in a loss of 1/4 to 1/2 a point on CR. Excessive deck height on the block similarly reduces CR. All of these items (and more) must be evaluated when an engine is built.
Not false advertising, just typical description of replacement pistons that were used in a factory 10.5:1 application. You don't get a particular CR just by the pistons used; the head combustion chamber volume and distance from the top of the piston to the head mating surface on the block (piston to deck clearance) affect CR as well. The piston to deck clearance is a combination of the piston compression height and block deck height.
Most factory-built production engines don't provide the CR that's advertised. This is just a function of mass production. There's a reason why racers "blueprint" their engines - to remove these production tolerances and ensure the engine is built exactly to the factory design. For example, advertised chamber volume for most SBO heads are 60-64 cc. These are the design specs, but due to machining and casting tolerances, the as-delivered chamber volumes are closer to 68 cc or more. This is done intentionally both to reduce scrappage rates and to allow room for the heads to be resurfaced in the future without excessively increasing CR. Contrast this to newer engines where there isn't enough material to overbore them and you need to replace the block if the cylinders are worn.
You MUST bore the block to match the pistons. Figure out how much the block must be bored, buy correct size pistons, THEN have the block machined to match (with appropriate piston-to-wall clearance). A machine shop should know this.
In your case, the regularly available pistons for a 350 Olds will be 4.057", 4.087", and 4.117". If you are using cast pistons, the piston-to-wall clearance should be 0.00075" to 0.00125", per the CSM. Forged pistons typically will want a little more.
Pistons typically come in standard sizes, usually the standard bore (4.057" for an Olds 350) and standard overbores of +0.030 and +0.060. Sometimes you can get other overbore sizes (like 0.020 over), and naturally custom pistons can be machined to whatever you want.
I just looked a their catalog.
http://www.dickmillerracing.com/imag...Rings_Kits.pdf
DMR-P5350
These are Diamond custom quality flat top forged pistons made exclusively for DMR in quantity so we can sell them to you at a price far less than custom pistons. Available for 350 Oldsmobile engines in +.030, +.068. 10.25 to 1. Flat top with 3.98 cc valve relief. Approximately 556 grams. Uses less drag 1/16x1/16x3/16 ring set combination with a .980 wrist pin. Includes spiral locks. Set of 8.
DMR-P5425
Same as DMR-P5350 except for 425 Oldsmobile engines in STD.+.030,+.060. 10.25 to 1. Flat top with 3.98 cc valve relief. Approximately 567 grams.
DMR-P5350
DMR-P5425
RandyS
January 15th, 2014 02:51 PM
