Dual valve springs
Old December 10th, 2020, 03:28 PM
Member
kevdog442's Avatar
Dual valve springs
Do my heads have to be machined for dual springs?
kevdog442 is offline
Old December 10th, 2020, 04:25 PM
Are you meaning "real" dual springs or a spring with a damper? If a spring + damper, no milling is required. I don't know about real dual springs, though.
Fun71 is offline
Old December 10th, 2020, 05:11 PM
Member
kevdog442's Avatar
yeah, double springs not including the damper. A spring within a spring. Comp cams website says machining required but don’t know what that entails
Old December 10th, 2020, 06:44 PM
70W-32's Avatar
Your valve spring pockets may need milling for the correct spring height to be achieved, and your valve guide may have to be machined for smaller valve guide seals to clear rhe inner spring
70W-32 is offline
Old December 10th, 2020, 08:38 PM
OLDSter Ralph's Avatar
Why do you think you need dual springs ?
OLDSter Ralph is offline
Old December 11th, 2020, 03:36 AM
Member
kevdog442's Avatar
Bought a cam, then realized it called for a spring that was double. Didn’t know about this. Maybe someone can recommend single spring that will work? The cam is 485/.490 lift.
Old December 11th, 2020, 03:57 AM
Member
kevdog442's Avatar
455 and my shortest installed height is 1.65”
Old December 11th, 2020, 04:05 AM
Oldsmaniac's Avatar
Many years ago I had heads done with double springs, the shop said there wasn't any room now for valve stem seals... so none were installed.
Oldsmaniac is offline
Old December 11th, 2020, 06:48 AM
Old(s)GuysRule
67OAI's Avatar
Spring pockets are close to the water jacket on Olds heads; don't recommend cutting the spring pockets. Plenty of dual springs available for you or you may want to look into the "beehive" springs that are available. If you choose dual springs your valve guides will most probably have to be machined for smaller outside diameter valve seals. Look to your cam manufacturer for valve spring recommendation.
67OAI is offline
Old December 11th, 2020, 07:00 AM
Member
kevdog442's Avatar
I always thought if you stayed under .500 lift then stock springs were ok
Old December 11th, 2020, 08:15 AM
What brand cam ? What Duration ? Hydraulic grind ? Flat tappet ? RPM range ? Why did you choose that cam ?
Old December 11th, 2020, 08:20 AM
akspeedy's Avatar
I also thought under .500 lift stock style were fine, i am running stock style spring with a dampner and my cam lift is .500.
akspeedy is offline
Old December 11th, 2020, 08:43 AM
The UD cam in my engine is that lift and I used regular factory replacement springs with a damper, and the engine will easily rev to 5600+ RPM.
Fun71 is offline
Old December 11th, 2020, 09:33 AM
Member
kevdog442's Avatar
comp cams xe224-230 hydraulic flat tappet
https://www.compcams.com/xtreme-ener...e-260-455.html
Old December 11th, 2020, 10:04 AM
New 1970 W-30 valve springs and dampers shimmed to 1.67" will be more than enough for that cam.
......Just my two cents worth.
Old December 11th, 2020, 10:32 AM
Member
kevdog442's Avatar
Thats what I’m thinking
Old December 11th, 2020, 10:47 AM
Member
kevdog442's Avatar
Is there any way to find out specs on factory springs? Looked in service manual but it didn’t say, I sent an email to Supercars Unl. But never got an answer
Old December 11th, 2020, 11:14 AM
70W-32's Avatar
Contact Comp Cams directly
70W-32 is offline
Old December 11th, 2020, 05:22 PM
Olds Performance Machine's Avatar
A dual valve spring in most all cases requires the reduction of the seal area of the guide. The factory guide is around .590 and then when a seal is installed onto it, it will typically run interference with the i.d. of the inner spring on a dual spring. We frequently reduce the o.d. of the guide and install a .530 seal. This will allow for a dual valve spring. You can check out lots of tech tips and videos at Olds Performance and Machine on facebook. Thanks.
Olds Performance Machine is offline
Old December 11th, 2020, 06:03 PM
Member
kevdog442's Avatar
Great info, thanks
Old December 12th, 2020, 07:19 AM
Old(s)GuysRule
67OAI's Avatar
Ditto what Ralph mentioned in post #15 above (if you can find them). They are considerably stiffer than the non W30 valve spring and should work fine up to .500" lift; and you can use stock valve seals with them. On a separate but similar note, if someone has the means to research this, I recall a Chevy 409 factory valve spring that had the same specs as the Olds W30 spring.
67OAI is offline
71OldscutlassS
October 8th, 2023 05:51 AM
Racer_X
July 13th, 2018 06:29 AM
generalmopars
January 25th, 2017 10:00 PM
1978 Oldsmobile Omega
February 8th, 2016 05:34 PM
pogo69
March 31st, 2014 05:01 PM
Quick Reply: Dual valve springs
