Drain Door Seals
Old Sep 29, 2014 | 04:54 AM
ostie13's Avatar
Drain Door Seals
I just got off ebay and had found the rubber strips that plug the bottom off the door drains.I looked to see if mine were still there and they were not.It looks like to me if they were plugged that the water would just stay inside the door and rust it out.What is the reason you would want them to be in there anyway.They were put there for a reason,I just want to know why.Did all cars have them?
Old Sep 29, 2014 | 05:53 AM
5998DownUnder's Avatar
My 59 98 has them. When working correctly, my style are almost like a little door that gets pushed open by the weight of the water on the rubber, the water then runs out, rubber must then resume its closed position.
There to keep dust/fumes? from going in maybe!
Old Sep 29, 2014 | 11:31 AM
rocketraider's Avatar
Oldsdruid
As downunder says, they help keep dust out while allowing water that gets by the window belt seals to drain out.
Doesn't hurt to reach behind them once in a while and clean out any dirt and debris that has gotten in there (and believe me it does). The CC wagon passenger front door has always been bad about it- you'd hear water sloshing after a heavy rain but tickle that drain port and water'd pour out for several minutes.
Not 100% sure but I don't think either of my Fords has those seals.
Old Sep 29, 2014 | 11:32 AM
ostie13's Avatar
I have those on my Toronado but its on the trunk. Four of them.
jag1886
Apr 1, 2013 05:43 PM
panos
Body work
Nov 16, 2012 07:00 PM
cheven
Jun 10, 2012 04:27 PM
65OldsDelta88SuperRocket
Jan 2, 2012 10:55 AM
va88
Jul 20, 2007 04:39 AM
