door edge guards
Old Apr 8, 2020 | 12:38 PM
chip-powell's Avatar
door edge guards
I ordered door edge guards for my '71 cutlass from Fusick. Today they came in and the label on them says that they are for a '68-'69 Cutlass. I called Fusick and they said that the edge guards for a '71 are no longer reproduced, so they sent these instead(?!?!?!?). Made no sense to me either.
I do not believe that they do, but before I return these, will door edge guards for a '68-'69 fit a '71 (and look correct)?
Old Apr 8, 2020 | 04:43 PM
I have a repop set of these that are supposed to be for a 70-72. I'm never going to put them on because I'm too chicken. I'm really worried they will take off the paint. Anyway I don't know if the ones you have will fit, but if not I'll sell you the set I have. If you're interested PM me.
Old Apr 8, 2020 | 04:56 PM
I had the same concerns after repainting my car and never reinstalled the door edge guards. The opening on them is so thin they will not go over the thicker paint job without removing most of the paint. A while back I found some silver plastic door edge guards at an automotive paint supply house that from a distance look the same as the metal ones, so I put them on instead. They are like a plastic tube that's slit along the edge and they slip on very easily with no chance of paint damage.
Old Apr 8, 2020 | 05:38 PM
vintagepne's Avatar
You might try Don’s Auto Parts in Oregon they have door edge for a lot of GM cars i’m not sure about your specific model but it might be worth checking. donsautoparts.com
Old Apr 10, 2020 | 02:12 PM
Thanks for the advice everyone. I had not thought about that vertical line created from having them installed and the odd look that it would create. I think that I'm going to hold off for now.
Driftr
Jul 8, 2011 10:56 AM
Southern_Hospitality
Aug 19, 2008 01:58 PM
gumbyssfakee
Aug 6, 2008 10:36 PM
May 10, 2008 09:58 AM
frostbyte
Dec 5, 2007 04:02 PM
