Door compatability question
The door shells are the same, but be aware that convertibles have wedge plates added to the rear edge of the door. Look at your convert door and you'll see a small plate that wedges against a mating plate on the door jamb. This helps prevent sagging. Simply transfer the plate from the old convert door to the hardtop door. I believe the two screw holes are already punched in the door. Repros of the plates and shims are available.
Timcando
October 29th, 2013 09:00 AM
