Does this come off
Old Sep 9, 2023 | 11:24 AM
tkcutlass's Avatar
Does this come off
Trying to freshen up my wiper motor.
I can't seem to get the bottom off.
Is all rusted and I would like to soak it in evapo rust.
Is the bottom supposed to be able to come off or should derust some other way?
Old Sep 10, 2023 | 11:10 AM
70Post's Avatar
Tim - That lower housing is STAKED to the blue colored metal/"magnet looking" part of the assembly. If you clean off the metal some up towards the upper edge of the housing you should be able to see 3-4 PAIRS of small stake marks in the housing. Sharp/small pairs of depressions.
As far as actual removal....I'll have to go take a look at a couple I have. I know one of the wiper motor restorers replates that lower housing so I assume they are able to remove and reinstall that part somehow. There is a captive bushing or bearing in the bottom/center of the inside of that housing....holds the end of the shaft and I assume has some grease/lube in it. Don't think that bushing/bearing is removable as it appears to be spot welded in place inside the housing.
Nov 15, 2022 05:07 PM
70-455
Jan 26, 2022 12:27 PM
Jan 10, 2022 11:22 PM
Elite Carpentry
Mar 22, 2021 12:50 PM
72455
Care and Appearance
Jan 17, 2019 01:26 PM
