Do You Speak Hot Rodder?
"Elephant" only applies to the 2nd Gen Hemi? I thought "Elephant" began in the '50s with the first-gen Chrysler Hemi (not so much with the DeSoto or Dodge Hemi).
The whole point of calling the SBC the "Mouse" motor was the old story of Elephants being scared of mice.
......Just my two cents worth.
Well, for one, they got "pancaked" wrong. Or more precisely, this is the more modern version. (1990's-up)The original version meant cutting off the front of a hood overhang on an older car, to make the opening part of the hood flat, or flatter. Some even went so far as to completely weld the hood shut, then cut out a much smaller opening, only on the top, making almost completely flat.
Knew most of it but never heard of uggadugga either.
Bellflowers look good on cars with enough length between rear wheel opening and bumper. Neighbor has a black cherry 04 Grand Marquis he put them on and they set it off.
We had a local expression called 'Cave man'. For example "You really did a caveman on that part to make it fit". In other words, used whatever tool was around or whatever fasteners were used to affix it. It could even be a part that was different and needed a bit of convincing to fit. Kind of rough around the edges so to speak but it did the job. I honestly thought 'Ugga-dugga' meant you torqued in on by hand hard as you could muster with whatever said tool was around that could reasonably do the job. See "Tighten it up till it breaks then back it off half a turn'.
Torque values;
Turn it 'till it squeaks and spit on it...
Tighten 'till it smokes and hit it with a rock...
Turn it another blonde, red, brown hair...
Hang out in a fun diesel shop long enough and you'll pick up on them.
....And we can't forget the requisite cussing up a storm!
I seem to recall the early Hemi's just being referred to as a "hemi". When Keith Black and Ed Donavan introduced a "426 style hemi" block for top fuel, the term "Elephant" motor was coined. After that came the "Mouse motor", "Semi Hemi", "Rat motor" nicknames. The nicknames stuck. Today the nicknames "Small block" and "Big block" cross manufacturer lines to specify engine blocks style.
Actually Ed Donovan based his 417 hemi on the 392 Black based his on the 426.
I guess I speak fluent Hot Rod. I know most of the terms mentioned. Never heard this definition of pancake before, that’s a new one.
The definition of pancake I’m familiar with usually revolves around the off road crown, meaning putting a truck on the roof snd flattening the cab.
That’s a movie that would never be made today. Definitely a time when society wasn't so easily triggered, you were allowed to have a different opinion or point of view without worrying about offending anyone.
There are many phrases and quotes from those movies (along with Fletch, the Naked Gun) that I use as often as possible. Unfortunately, I need to work with a older crowd. Most kids don’t get the references.
