Disc brake Conversion trouble 72 cutlass
Old Jun 4, 2018 | 07:36 PM
Doorman1970's Avatar
completed a drum to disc conversion on the front wheels only and can’t seem to get a good petal it’s drivable but won’t lock up brakes I have blead them several times and also bench blead the master before installing any thoughts ?
Old Jun 4, 2018 | 10:17 PM
What parts did you replace?
Did you install a combination valve in place of the distribution block?
Did you use factory parts from a donor vehicle or new aftermarket stuff?
Old Jun 5, 2018 | 06:40 AM
Installed all new parts booster master slotted rotors stainless braided hoses calipers prop valve also did remove the old distribution block on the frame
Old Jun 5, 2018 | 06:51 AM
edzolz's Avatar
Do you have access to a pressure gage? Check front pressures versus rear. Also, did the kit come with the master cylinder? You may need to change to a smaller diameter master to get better pressure.
Old Jun 5, 2018 | 09:12 AM
Might be able to get pressure gauge kit I bought cane with everything just wondering about pin length from the booster to the master it came with the short pin in the booster and the “bullet” for the master but I’m wondering if it should have the longer pin there were no instructions on what to use
Old Jun 5, 2018 | 09:16 AM
The petal doesn’t go to the floor but I can’t get my other foot under it when it’s down - kind of scary if you don’t expect it !
Old Jun 5, 2018 | 09:21 AM
Either you still have air in the system (the most likely cause) or you have a mis-adjusted pushrod either between the booster and M/C or between the booster and the pedal. The brake system is not complex. There aren't a lot of other potential causes here.
Old Jun 5, 2018 | 09:25 AM
Ya I know it shouldn’t have to be that hard I’ve done many brake jobs this one keeps kicking my butt I’ll probably try another round of bleeding
Old Jun 5, 2018 | 09:36 AM
Are you running the small booster? If yes, there has been many discussions on the dramatic difference in braking power with it.
Old Jun 5, 2018 | 09:40 AM
No I have the stock size booster
Old Jun 5, 2018 | 09:45 AM
dalilama's Avatar
I did the same upgrade on my 1972. The proportioning valve gave me fits when trying to bleed the rear brake. You have to ensure that the valve piston is centered between the front and back brakes during the bleeding process. You should remove the switch at the top and visually inspect the valve piston to ensure it's centered and center it if it is not. I used a small pick to move the valve piston to center and then the bleeding was successful. I also purchased a bleeding "tool" that held the piston steady during the bleed. You can get one here:
https://www.speedwaymotors.com/Speed...iABEgLPevD_BwE
Hope this helps -
Old Jun 5, 2018 | 09:54 AM
I had some trouble with that in the beginning but I’m pretty sure that if fine I tested it with a test light to check and make sure it wasn’t pushed to one end so hopefully I can just get it by more rounds of bleeding!
Doorman1970
Brakes/Hydraulic Systems
May 16, 2018 08:21 AM
irkennedy
Jul 12, 2017 02:34 PM
caboose55
Feb 6, 2012 04:53 PM
BerBer5985
Jan 23, 2010 09:55 AM
JCervantes
Dec 28, 2008 07:39 PM
