Diesel Chevy trucks
Diesel Chevy trucks
So, apparently there are 2 mounting systems for the Olds diesel in chevy trucks.
One system uses a rubber-less motor side bracket and the chevy style clamshell mount on the frame side. (Anchor #2292).
The other system uses a rubber mount on the motor side and a rubber-less motor perch on the frame side. (Anchor #2328).
Just putting it out there. My '79 Chevy has the second style. Found out after buying the wrong mounts yesterday.
sb
sb
sb
sb
When I first read this I wondered if its the one they used in trans ams with the 403...and it is.
It appears they were used in a LOT of gm vehicles, including trucks. I learned something too.
http://frugalmechanic.com/auto-part/...eft-mount#fits
[quote=joe_padavano;23819 The diesel trucks used the same frame clamshells but the engine brackets are longer than on the car applications.[/quote]
I have a set of those brackets off a fire chicken. Looks like I need to find any kind of chivvy to put one of my olds 350s into.
sb
sb
jaunty75
January 13th, 2014 08:50 PM
lshlsh2
April 19th, 2009 05:12 AM
