Dash Speaker Cover 80 Olds
How does one remove the Dash Speaker Cover 80 Olds.
The plastic is brittle and I have my concerns on the amount of resistance I can expect.
Do I have to pull the whole dash?
RonzBoyz
RonzBoyz
If you are talking about the two small covers, they pop off. There are 4 spring clips, one on each corner. They do take a bit of pressure to get off. Use a wide flat pry tool closest to the corners and protect the dash under the tool. If it breaks, then it will need replacement anyway. There is no way to get them off by removing the dash.
Hope they do not break.
