D head questions??
Old Jan 28, 2017 | 06:59 PM
Bernhard's Avatar
D head questions??
On ebay there is a set of Oldsmobile D heads up for sale.
One head has a large heat riser opening the other a small heat riser opening.
Why would there be a difference in heat riser openings on D heads?
I understand that they are most likely not a matched set of D heads and from different production runs.
Could the one D head be a early 68 production run while the other is a 69 head?
What was the last year of the small heat riser opening ?
http://www.ebay.com/itm/Oldsmobile-4...hYd8hS&vxp=mtr
Old Jan 28, 2017 | 08:14 PM
83hurstguy's Avatar
Good question. My D heads have the small heat riser with a 110 date code. Not original set to my car, so I'm not sure the original application. I've wondered the same but never looked into it.
Old Jan 28, 2017 | 09:21 PM
Bernhard's Avatar
I have four sets of C heads the ones that came off a 1967 425, had small heat riser openings. While all the others that cam off 69 cars have had the larger heat riser.
I personnel like the small heat riser heads as it is a smaller area to close off.
young olds
Jun 3, 2014 08:13 PM
Olds Scott
May 29, 2013 08:15 PM
Ragtopw1972
Oct 18, 2012 08:19 AM
CLcutlass
Aug 21, 2011 06:25 PM
esisson
Mar 17, 2008 12:13 PM
