Cutlass by numbers
Old Apr 26, 2021 | 10:31 AM
Never2olds's Avatar
Cutlass by numbers
A friend just bought a 1970 Cutlass S that originally came with the 455/TH400. I think it's pretty odd because it's got all you would want in a 442 without being one. Not an SX either.
Anyone has production numbers on it?
Old Apr 26, 2021 | 10:41 AM
The L33 320 HP 2 barrel 455 with dual exhaust was not the same beast as the 365 HP 4 barrel 455 in the 442. The currently available production info does not go into that much depth, to my knowledge. It is a very common upgrade to change intake and carb to the 4 barrel version, and almost as common to upgrade a cam, but, from the factory, it was rated 45 hp less than the 442.
RPO L33 was the 2bbl 455, only available in the Cutlass line through Feb 1970. After that, the L33 was dropped and only the 350 was offered. The L31 4bbl 455 was only available in the Supreme with the SX package.
Old Apr 26, 2021 | 11:48 AM
Never2olds's Avatar
Thanks!
Old Apr 26, 2021 | 11:49 AM
Never2olds's Avatar
That's great! Even though the 2 bbl was considerably less desireable, it still means his was likely a very low production car, being that it was cancelled so early on! :-)
Old Apr 26, 2021 | 02:42 PM
How about some more pictures. Especially under hood shots. Pleeaassee...
Old Apr 29, 2021 | 09:39 AM
Never2olds's Avatar
The engine isn't currently in it.
Old May 1, 2021 | 10:05 PM
69CSHC's Avatar
So cool ! Best of luck to him with it.
Rare for sure and definitely the way I would want a Cutlass S. But it couldn't touch a 442 in performance. 15 seconds flat in the 1/4 vs 14.5 and forget about a W30, it couldn't even smell its exhaust. The beauty in it is that its up to 250 LBS lighter and most will figure its a 350 powered version. So you own a big time sleeper that can get modded relatively easily to match 442 performance ... All the while saving a pretty penny because it doesn't carry the legendary moniker.
Old May 3, 2021 | 11:34 AM
Never2olds's Avatar
Yes, but then, the eterneal question: should he build it back to factory stock spec because it's uncommon (I figure probably between 400 and 800 units produced in total), or go all-out with it? Decisions, decisions...
Old May 3, 2021 | 03:04 PM
Andy's Avatar
Its like a turnpike cruiser, low numbers, interesting but why not add the 4bbl, the cam and give it the power it deserves.. no real extra value in cars that were low production but slooow..
tom54tay
Apr 1, 2019 10:26 AM
wmachine
Apr 25, 2009 09:45 PM
mugzilla
Mar 6, 2009 05:43 AM
Michael C. Nazaruk
Sep 11, 2006 05:46 PM
