Cutlass Fiberglass 442 Hood Question !
Old Aug 20, 2018 | 10:41 PM
Benji Breh's Avatar
Angry Cutlass Fiberglass 442 Hood Question !
Hello Fellow Old people I have a 1972 Cutlass (not a 442), and purchased a 442 hood and had it installed while I got it painted. I believe the hinges were done improperly and the hood shuts too low and isn't flush as seen in the pictures (red circle). I was wondering if there's a way I can make it flush again by maybe getting longer adjustment screws so it sits higher or any other ideas you guys had in mind. Thanks in advance!!!
Side question: If my convertible top switch isn't working (it's like stuck and wont press down, only up to close the top), does this mean I need a new switch ??
Old Aug 21, 2018 | 05:38 AM
There are adjustable bumpers under the leading edge of the hood that are designed to adjust exactly that fitment.
And yes, I'll be the stickler for correctness and point out that what you have is not a "442 hood". In 1972 442s came with a hood that looked like this:
The hood you have is a reproduction of the optional outside air induction hood, and it was available even on your Cutlass under RPO W-25. Good luck with the car.
arcticman
Sep 23, 2018 02:01 PM
sumrhosr!
Nov 27, 2017 09:56 AM
pacekar
Jun 15, 2016 06:36 PM
Amirax
Jan 26, 2016 10:33 AM
Kyle's 77 Cutlass
Jan 11, 2011 08:39 PM
