Cruise control
Post some pictures, there are a lot more parts to the set up than one would realize. Another member just posted a link to a great guide on these setups so that will show you all the parts you need to take off. Most likely it will work on many years, maybe even 71 - 78? Worth something to someone.
X2 on the number of parts you need to remove for it to be a complete setup for someone.
You've got the turn signal stalk w/wiring pigtail, lower dash panel rocker switch, brake pedal brkt with vacuum cut-off switch, wiring harness out to the Regulator, Regulator itself, Servo w/mtg brkt and throttle linkage, both Speedo cables (one from speedo to Regulator and from Regulator to Tranny) and, required vacuum hoses.
JMO, But why remove it... It will cost you in time and possibly money for a minimal return... A significant item necessary is the turn signal level which operates the cruise... Do you already have another lever to replace the cruise lever which may entail taking the column apart... You will have to cap off and/or reconnect vacuum hoses as necessary etc. etc...
