Creep of aluminium cylinder heads
Old Jan 17, 2013 | 12:01 PM
dancutlass's Avatar
I am currently learning for a test in materials engineering and just came to a chapter that treats creep.
Well we've learned in lecture that creep of a material starts at about 2/5 of it's melting temperature. With the melting temperature of Aluminium being at about 660 °C, the temperature where creep starts would be right at 264°C, which pretty sure is exceeded in an engine. (please correct me if I'm wrong)
Now my question is, how the engineers developing the aluminium heads forestall this phenomenon. Do they use any alloying components to raise the melting temperature, or is creep not relevant for cylinder heads, because there's not a static load stressing them?
Sorry for the long and kind of boring post, but I thought discussing it here would make learning more fun Actually I guess I've memorized a lot just by writing this
Old Jan 17, 2013 | 12:16 PM
Well, 264°C is 507°F, and though I would expect that the inner surfaces of the combustion chambers experience temperatures this high, I believe that the coolant carries the heat away quickly enough that only a fairly thin layer of material directly lining the combustion chamber sees it, and that only for milliseconds, as the new mixture charge is much cooler as it enters the chamber with the next cycle.
Old Jan 17, 2013 | 12:29 PM
jfb's Avatar
jfb
this is a good question but what about the opposite how cold is to cold before a problem can set in?
Old Jan 17, 2013 | 03:07 PM
We have a winner. Don't worry about the cooling effect of the intake charge hurting the aluminum. The thermal mass of the charge is so much less than that of the head that the charge heats up much faster than the head cools off.
Old Jan 18, 2013 | 08:06 AM
rustyroger's Avatar
'87 Delta 88 Royale
Pure aluminium (as we call it over here) melts at 660c, but the metal used in engines and most other applications is alloyed with other materials to add toughness, raise the melting point etc.
How cold is too cold?,
During WW2 the Germans fighting on the eastern front had a lot of problems getting there equipment to work in -40 temperatures, tires and metal often shattered in such extreme conditions. They had to run their vehicles every hour or so just to keep them operable.
Roger.
gearheads78
Oct 7, 2014 11:52 AM
SkylinesSuck
Aug 4, 2014 05:59 PM
D Appeldorn
Jun 4, 2012 10:18 AM
evans_78
Mar 2, 2012 11:18 AM
CLcutlass
Jul 28, 2011 07:51 PM
