Crankshaft ID
Crankshaft ID
This is the crankshaft drive flange in my 1970 Olds W-31. I am trying to get a pilot bushing but none are the correct size. There is no snap ring groove either for a bearing
. I can get one machined at a local machine shop but am trying to figure out if this is actually the correct crank for this engine.
Is your car a four speed car or are you just adding the four speed? There is a correct roller bearing that fits the four speed cranks and it has to be staked after installing thus no retaining ring groove. I'm sure someone will chime in with the bearing number needed. I have one NOS in my shop but I do not have it in front of me.
Why are you asking the same question you asked in your other thread? You will not get any different information no matter how many times you ask. The other thread has the information you need for the bushing number and the bearing number. Even newbies do not get different answers.
David DeCan
May 25th, 2016 11:50 AM
