Correct Alternator Mounting Barkers?
Old Aug 25, 2013 | 08:12 PM
dfire25's Avatar
"Trying to fix her right"
Am I missing something (see pics)? The bottom part of the alternator is supported my an obvious non-stock turnbuckle. It works, but what is the correct way? I have another bracket (see last pic) that I'm planning on using, but I've seen it with or without a back supporting bracket. Do I need the back bracket? By the way, I'm going to be using these brackets on my new 455.
Thanks,
Dave
Old Aug 26, 2013 | 05:38 AM
2blu442's Avatar
The first one needs a piece that's kinda triangle shaped. The second one is missing the H shaped piece. I know there's some old posts with pictures, if you have time try the search option with my name to see what comes up. The factory thought they were needed, I've never run an engine without them. But think it may vibrate too much and eventually break something without the support.
Both of these are common brackets. I've got extras of them both and know several other members here do too. I'd encourage you to decide which one to run with and create a parts wanted thread with your location and see what gets offered.
John
Old Aug 26, 2013 | 05:52 AM
RetroRanger's Avatar
72 Olds CS
Can't tell for sure but it looks like the PS bracket is missing the spacer where it mounts to the WP as well
Old Aug 26, 2013 | 08:00 AM
dfire25's Avatar
No it's there, two 3/4" nuts! I'm going to have to make something up to replace them.
Old Aug 26, 2013 | 08:04 AM
dfire25's Avatar
John
Thanks John. I'll probably go with the second one. I'll have to search out a "H" bracket then.
442mark
Sep 30, 2017 01:06 PM
chip-powell
Sep 5, 2014 03:58 PM
Nasty455
Sep 14, 2012 07:16 PM
Pacecar
Nov 28, 2011 09:40 AM
daddyjws
Feb 3, 2005 01:44 AM
