Correct air cleaner cover color
Old Nov 27, 2014 | 08:06 AM
krauser65's Avatar
HAPPY THANKSGIVING EVERYONE!
HEY, I got a 65 vista cruiser with a 2 barrel 330 SBO. Can anyone tell me the correct color for the air cleaner cover. I was told it's orange, red, and even gold to match the engine.
Thanx!
Rod K
Minot (freezing the reezin) No Dak land
Old Nov 27, 2014 | 08:43 AM
I actually think it's black.
Old Nov 27, 2014 | 09:07 AM
Black for low compression, Olds Orange for high compression.
In 1965, Olds made 2bbl 330s in either low or high compression, so it could be either, depending on what pistons are in it.
Old Nov 28, 2014 | 07:38 AM
krauser65's Avatar
thanx!! I thinks it a low comp engine.. so black it is. rk
Old Nov 28, 2014 | 07:52 AM
I was about to say "You never know..." but I checked the CSM, and for A-bodies in '65, there was no HC 2bbl option - HC 2bbl was only for the B-bodies (JetStar), whether BB or SB.
So, yes, the simple answer is "Black."
Old Nov 28, 2014 | 09:21 AM
stan 65 cutlass's Avatar
heres what was on my 65 fourdoor, 2 barrel
330 v8
econo v6
Old Nov 28, 2014 | 09:44 AM
Ho boy.
That sure does look like an original 2bbl air cleaner.
I just looked at the '65 SPECS Guide, and the '65 Assemby Manual, too, and it also shows only a LC 2bbl 330 for the A-bodies.
So, basically, you got me.
Maybe a mid-year change?
Maybe it would be worth it for the OP to check the stamped engine number on the front of the Right head, to see whether it points to a HC or a LC engine.
If it says it's HC, then I guess the documents that I know of are wrong.
TheBirds
May 9, 2020 02:14 PM
RAMBOW
Dec 7, 2017 07:22 PM
jvock6
Apr 30, 2012 10:31 PM
1969-442
Aug 11, 2010 03:16 AM
SIPLOWGUY
Dec 8, 2009 08:43 PM
