Cooling Question
Cooling Question
I have a radiator and flex fan from a 68 Delta 88 with A/C and 455 engine, when I put the 455 (.030) in my 67 Cutlass I used this radiator and flex fan and the engine ran 180 degrees all day. I just replaced the 455 with a 67 400 (stock Bore) and with the same Radiator and flex fan the engine temps go quickly to 210 plus. I have 180 degree thermostats in both engines. The flow thru the radiator after the thermostat opens is good. I flushed the block and radiator and the coolant was clean, no rust. My question is if this set up cooled the 455, why does the 400 run so hot? Thanks
Timing is set at factory 8 degrees, distributor is stock breaker point. I know todays engines run at 210 but being old school I like vintage engines to run around 180 to 190. At fast idle, I shut the engine off 210 and climbing, less than 2 minutes. Thanks
Yesterday's engines ran at 210 also, without problems. Engines that run hotter are more efficient. The thermostat only controls the temperature at which the thermostat opens, not the final operating temperature.
I have a '67 Delta 88 with a temperature gauge, and it routinely runs between 200 and 210 all day long with no problems.
You're chasing a phantom.
Ideally, the radiator should always be able to outcool the engine and the thermostat should regulate the system. Sort of like your home AC has a thermostat, and the AC system can always out-cool the heat, so it cycles (in a car's case, restricts flow). However, old cars are not ideal, so many thermostats just open and stay open, and the radiator does the best it can, which is why the temp fluctuates. (Also, I think new gauges are not very precise, so, along with good radiators, this is why it gets to 50% on a new car and stays there.)
Less than 2 minutes to get from ambient (cold start) to 210*?
If its jumping up to and over temp in 2 min's there is an air pocket in the system and it needs to be flushed out. I generally will leave the cap off and observe when the thermostat opens. Once it opens and starts to flow in the radiator, the level will drop and I stick the end of a low flowing garden hose into the radiator to force water in and flush the pocket out.
Things to consider:
- The radiator may have an internal blockage. When the engine was out, something may have gotten into the system and plugged some radiator tubes.
- The radiator may have an external blockage. Check for debris blocking air flow through the radiator fins.
- The 400 may be generating more heat, possibly due to something such as tighter piston-to-cylinder clearance, tighter bearing clearance, etc.
the best/easiest way to make sure all the air is out of the system is to jack up the front of the car, make sure the radiator cap is the highest point of the cooling system. Let it sit overnight, you may be pleasantly surprised to find the coolant level has drop significantly
These things work great for eliminating posible air pockets.
http://www.tooldiscounter.com/ItemDi...yABEgLo9_D_BwE
rjdawson
Aug 3, 2012 06:43 PM
