coolant coming out both exhausts
Old Aug 12, 2017 | 11:09 AM
truckman5000's Avatar
W30
Finally got the car running great!!!...
So it never used coolant before, but only about 100 miles since i re-did everything cooling related.
I took it out for a 20 mile beating to see if anything else will break. Noticed i needed to add 3- gallons of coolant.
Steam/ coolant coming out both pipes. Allot too basically sprays water out...
I know what it could be, but never experienced loosing 3-4 gallons so quickly
Old Aug 12, 2017 | 11:22 AM
It could be a lot of things, remember as the engine heats there is pressure pushing the water out. It does not take long to empty the cooling system.
Old Aug 12, 2017 | 11:23 AM
scottv442's Avatar
Maintained
Yup, you broke it.
Intake manifold gasket leaking into combustion chamber or blown head gasket.
air bubbles in rad with show head gasket failure.
Fix it before you loose your main, rod or cam bearings.
Old Aug 12, 2017 | 11:26 AM
W30
Yup you broke it..lol
I dont have a psi tester, but will get one.
No bubbles coming into the radiator.
I wish i can post a video, its alot of water
Old Aug 12, 2017 | 01:22 PM
Do you have water in your oil also?
Old Aug 12, 2017 | 01:39 PM
W30
No water in the oil. I did just change the oil yesterday that looked fine also.
Whats the easiest way to isolate intake / head leak?
Old Aug 12, 2017 | 01:55 PM
Tedd Thompson's Avatar
Leak down test should isolate it.... Tedd
Old Aug 12, 2017 | 01:56 PM
Either way the intake manifold is going to have to come off, I'd start there. I would not run the car anymore.
Old Aug 12, 2017 | 04:15 PM
CRUZN 66's Avatar
Olds Fever
I would start by pulling the spark plugs and see what is wet or not and check each cylinder for coolant... Also, if you are running dual exhaust and are not using an x-pipe/h-pipe, you obviously have a problem on both banks of the engine...
Old Aug 13, 2017 | 10:34 AM
W30
So i got the manifold off.
The 1st 2- bolts were very corroded ( had to tap the threads also) and the gasket area around the water ways are very pitted.
The aluminum w-30 manifold is very pitted ( like chunks missing around the water holes.
Still a bit of gasket sealing space.
My mechanic friend stopped by. He said that the cooling passages are horrendous. And the heads would have to be milled. AND should pull everything apart and replace all the gaskets/ clean the block.
Witch i agree...
The engine has 2k miles on it, but it sat for 20 years. It has roller cam/ rockers, ported F heads.
Oh and the heads are studded so i have to pull the motor anyways ( a/c car).
At a cross road. Thinking aftermarket heads/ intake. But i just got a brand new q- jet.
Is there a performance spreadbore intake? That will fit the w-30 air cleaner?
Old Aug 13, 2017 | 07:44 PM
zeeke's Avatar
Possibly Offenhauser, but I think it's a single plane.
Old Aug 14, 2017 | 07:03 AM
scottv442's Avatar
Maintained
Witch i agree...
Must have sat with coolant in it for 20years? Coolant will become acidic over long time of sitting and eat aluminium intakes, seals and gaskets.
Edelbrock performer is a spreadbore intake, but sits a little higher than W30 intakes, so hood clearance could be an issue. See if your W30 intake can be repaired first.
Old Aug 14, 2017 | 01:56 PM
W30
thanks, I replaced intake, got it running. Well see it seems ok....
71DP
Jul 19, 2016 07:23 AM
cutlassw32
May 5, 2016 03:54 PM
Napoleon1991
Apr 13, 2016 06:20 PM
5998DownUnder
Ninety-Eight
19
Jan 21, 2014 07:00 PM
64 Olds Dynamic 88
Jul 25, 2008 10:30 AM
