Converting a ‘66 Starfire from TH400 Auto to Muncie 4 speed manual: what am I missi…
Old May 2, 2025 | 12:55 PM
  #41
las27563481's Avatar
None taken. I just didn't want to cut the tunnel in my W-31.
Old May 2, 2025 | 04:17 PM
  #42
z11375ss's Avatar
Senior Moment Member
That I can absolutely understand. I was dealing w/ a non numbers match but very nice car. Just a plain old Cutlass S. The kind my parent's drove. I owned 4 of these through the years. Really like the W-31 to the point I put one together.
Me putting the small block in my 68.
Old May 2, 2025 | 04:33 PM
  #43
cfair's Avatar
Gang,
The ‘66 Stafire, other than the trim is basically a 2 door Olds 88 with a concave back window (shared with the Grand Prix’s from Pontiac).
I’m naively optimistic that these larger cars should have less trouble accommodating a manual transmission - even a 5 speed. They were large to begin with.
Even if manuals back in the day were rare, GM built some that way. I think I’d stop short of cutting up the floor, but a relief cut here or there wouldn’t fuss me much so long as it could weather and sound sealed after what ever mods were done.
Many thanks again for all your thoughts from Muncie, to TKX, to Borg Warner. It’s exactly this kind of discussion which makes this forum so valuable.
Chris
Old May 2, 2025 | 06:23 PM
  #44
Whoops. I was thinking of the mid 70's small body Starfire. I was going to build one of those as a drag car, but just didn't have the means at the time. The 66 is a totally different platform. I would never recommend the T50 for that car. The Tremek is the way!
Old May 2, 2025 | 09:30 PM
  #45
cfair's Avatar
Mid-60’s & Mid-70’s Starfires are, uh, yup, very different platforms. Many thanks for the vote on Tremec.
Chris
Old May 2, 2025 | 10:25 PM
  #46
OLDSter Ralph's Avatar
The Starfire name was also used in 1954.......
Old May 3, 2025 | 05:49 AM
  #47
What about using a Borg Warner T-50.
The T50 may be the only domestic five speed that's weaker than a T5. Olds only put it behind the 260, since anything stronger would have fragged that trans by the time you reached the end of the driveway. And if you have to drive the car with an egg between your foot and the pedal to prevent hurting the trans, why bother with it in the first place?
Old May 3, 2025 | 08:06 AM
  #48
z11375ss's Avatar
Is there an echo in here?
Old May 3, 2025 | 08:15 AM
  #49
Even in the H-body cars with the V6 it was a marginal trans
Old May 3, 2025 | 08:34 AM
  #50
z11375ss's Avatar
I had one on my riding lawnmower, I think.
Old May 3, 2025 | 05:43 PM
  #51
cfair's Avatar
Anybody have a good article, video or source on basics of mechanical clutches with throwout bearings? And/or maybe something that explains how the hydraulic equivalents work?
I have the general impression that the various ratio gears on a sliding rod which is engaged to the input shaft in whatever gear the driver select until the clutch is depressed and it separates the input shaft from the ratio gears. How a clutch actually disengages the two (and more rods - driver & driven) is a complete mystery.
Seems like something the big 3 might have done some training materials on back in the 50’s-60’s, no?
Chris
Old May 3, 2025 | 05:45 PM
  #52
cfair's Avatar
Since we are talking about a big block Olds 455 as the engine, were there any more than one model bell housing used with 400/425/455’s? I have the impression that there’s just one that fits a big block olds, but I don’t know. I’d hate to buy a small block one and have it not fit…
Suggestions?
Thanks again for all your help
Chris
Old May 3, 2025 | 06:00 PM
  #53
fleming442's Avatar
Bellhousings are same across big and small block. The Lakewood weighs 28lbs and Quick time is 33lbs.
Old May 3, 2025 | 06:39 PM
  #54
That is correct, I've used the same bellhousing on my Cutlass when it had a 350 and a 455.
I don't now how weak the T50 really is, but it lived in the Cutlass behind my 455 (TRW forged 10.5:1, (Mondello) Engle Cam, HS roller rockers, 800 DP Holley, Torquer intake, and E heads). I have 295-50x15's in the rear, but I can say the car never hooked and I did hold back a bit on harsh shifts. I replaced it with the TKO because of the T-50's reputation.
Old May 3, 2025 | 09:39 PM
  #55
cfair's Avatar
Not that I’m worried about weight in a ‘66 Olds big car, but is there a performance or strength difference between the Lakewood and Quick time products?
Old May 4, 2025 | 02:26 AM
  #56
fleming442's Avatar
The Quicktime is definitely beefier. It has a plate where the trans mates. The Lakewood is formed.
Old May 4, 2025 | 09:51 AM
  #57
z11375ss's Avatar
I recently learned how transmissions are destroyed. The drive shaft in the trans actually flexes when you put a bunch of power to it. This misaligns things in the trans leading to failure. Am I right or no?
cfair
Sep 19, 2023 05:14 PM
MichiDan
May 15, 2017 01:45 PM
Jetstar 88
May 25, 2012 07:37 PM
dmcianfa
Dec 2, 2010 03:40 PM
