Comments on this '70?
Among other possible items to pick, what's the deal with the data plate?
http://www.ebay.com/itm/Oldsmobile-4...-/232080494270
pretty nice car all in all. interestingly this has the wiper fluid container on the driver side 9like mine) but it looks as if the passenger side was never drilled for it, though those inner fenders good be new/repos.
Also I thought hardtops had the spare under the package tray not where its located, isn't that for convertibles or is that all 70s?
One of the rarest 1970 442's made - the one that was not suppose to be built - a 4-speed with A/C. The M-21 was not available with 3.23 gears, so A/C was not suppose to be available. But the factory did build them if the dealer pushed the zone manager enough. According to the build sheet, the factory installed the M-21 with the 3.23 axle ratio and A/C. This is only the second one I've seen, with a third never seen but spoke to owner about it. Always thought Olds might had installed the M-20 with the 3.23 gears and A/C, but I guess Olds engineers determined the M-21 and 3.23 gears would suffice with the 455. A nice car with oddly matched options.
On the other hand, the 1970 SPECS booklet shows that 3.23 WAS available with M21 that year, and in fact was "standard and only available with C60".
Here's the 69-72 decal from the OPGI web site:
You are thinking of the VIN, not the Fisher Body Number. I've seen a number of early cars where the leading zeros were truncated on the body number.
help442onguam
March 24th, 2011 07:31 AM
lshlsh2
October 18th, 2010 05:52 AM
nelsontj
June 9th, 2009 03:35 PM
