Coil Question
Old Sep 15, 2010 | 10:18 AM
Coil Question
What does it mean when a coil must be used with an external resistor? Does it mean a firewall mounted voltage regulator? I have a '71 Supreme with the firewall mounted voltage regulator, and want to make sure I have the correct coil for my application.
Old Sep 15, 2010 | 10:55 AM
TripDeuces's Avatar
The resistor is for the points so you don't burn them up while running. You should have a heavy resistor wire already going to your coil so an additional resistor won't be needed. The resistor wire will have a thicker covering on it then other wires. Fairly easy to recognize. Other manufacturers used ballast resistors (ceramic block with a wound wire inside). Sounds like you have a generic coil that's just reminding you to use a resistor. If you don't have points and have converted to a Pertronix like ignition it's a different story.
This has nothing to do with the voltage regulator.
Old Sep 15, 2010 | 09:15 PM
Thanks.
O's_Car
Suspension & Handling
Apr 11, 2011 04:24 PM
77GCSX
Jan 25, 2011 02:53 AM
matt68
Sep 11, 2009 05:19 PM
J-(Chicago)
May 20, 2008 03:43 PM
68conv455
Feb 20, 2008 02:36 AM
