Clear thermostat housing
Old Mar 7, 2021 | 08:00 PM
shiftbyear's Avatar
Has anyone tried one of these? I don't even know if they're available yet. The company, Cool View shows OUT OF STOCK on every product.
https://www.classicindustries.com/product/vp2012.html
Old Mar 7, 2021 | 09:23 PM
Looks like a potential coolant leak to me.
Old Mar 8, 2021 | 04:43 AM
Beat me to it. What's the purpose of this? Oh, ah, look at the green coolant...
And every one of those joints between aluminum and plastic is a leak waiting to happen.
Old Mar 8, 2021 | 05:55 AM
Don’t forget the matching clear distributor cap. Wasn’t there a company that made clear valve covers? See thru air cleaners? Thing of the marketing possibilities!!!
Old Mar 8, 2021 | 06:47 AM
RetroRanger's Avatar
72 Olds CS
Haha luddites everyone of you....
benefits include:
you could see if your thermostat is opening and closing w out taking it apart and testing it.
you could see the accelerator pump working or not w out taking the lid off the air cleaner, and those sweet purple anodised carb bits might be able to be seen instead of being hidden by the air cleaner.
Old Mar 8, 2021 | 07:02 AM
redoldsman's Avatar
Proud Viet Nam Veteran
And nobody mentioned it is on sale for only $166 and will be arriving soon. Who in he heck would spend that much money for something this goofy. I am sure there are people that will. You do get free shipping though. What a deal.
Old Mar 8, 2021 | 07:26 AM
My temperature gauge already tells me that.
Old Mar 8, 2021 | 07:27 AM
Any bets on how long these items STAY clear?
Old Mar 8, 2021 | 07:33 AM
Bfg's Avatar
Bfg
I hope to be the first one on my block to have one.
Old Mar 8, 2021 | 09:05 AM
redoldsman's Avatar
Probably a pretty good chance you will be.
Old Mar 8, 2021 | 09:55 AM
mrolds69's Avatar
A few months ago somebody posted pics of an old show car from the 60's. It had a clear differential cover. Well...at least it was clear when new!
Old Mar 8, 2021 | 10:50 AM
HighwayStar 442's Avatar
Borosilicate glass, not plastic. Used in boilers. very low coefficients of thermal expansion. Good glass! Should stay fairly clear. Just saying.
Old Mar 8, 2021 | 10:52 AM
Originally Posted by HighwayStar 442
Borosilicate glass, not plastic. Used in boilers. very low coefficients of thermal expansion. Good glass! Just saying.
And how does the CTE of borosilcate glass compare to that of the aluminum end fittings?
Old Mar 8, 2021 | 10:54 AM
I fall back to you! What is it? It's been a long time I have worked on a steam boiler. I kind of reminder rudder fairalls and compression nuts
Old Mar 8, 2021 | 11:01 AM
A quick Google search shows aluminum has about 8x the CTE as does that glass. 24E-6 vs 3.3E-6 in metric units. Boiler steel has about half the CTE of aluminum, by the way, so about 4X difference between steel and that glass.
Old Mar 8, 2021 | 11:13 AM
Technology just keeps marching on. Aluminum construction with Buna N seals. Nylon glass? https://www.grainger.com/product/1U9...B&gclsrc=aw.ds
Old Mar 8, 2021 | 11:16 AM
Big difference between a liquid level gauge at ambient pressure and temp, and a t-stat housing a 210 deg F and 16 psi.
Old Mar 8, 2021 | 11:21 AM
Technical Specs
  • ItemClosed Circuit Liquid Level Gauge
  • TypeRigid Plastic Sight
  • Mounting Centers (In.)12 in
  • Mounting Thread1/2-20 UNF
  • MountingFront
  • Max. Operating PSI 125 psi ******
  • Max. Operating Temp. (F)225 Degrees F*******
  • Sight GlassNylon
  • ConstructionAluminum
Old Mar 8, 2021 | 11:24 AM
Technical Specs
  • MountingFront
  • Sight GlassNylon
OK. Feel free to put one on your t-stat housing.
Old Mar 8, 2021 | 11:29 AM
Joe, I never said I wanted too. Just like the back and forth witty banter.
Old Mar 8, 2021 | 11:42 AM
Old Mar 8, 2021 | 12:19 PM
Gentlemen, as fuel for the debate, I must say that I am not concerned about the material remaining clear, rather, I am concerned about the deposit of "scuzz" on the inside which will render it opaque. Observe the inside of a used radiator hose, it is not clean.
Old Mar 8, 2021 | 02:00 PM
My only experience with this type of glass in steam boiler is that it remain fairly clear. With a very light scuzz. Even in water that has many materials found in local water supplies. I alway use distilled water in my cars. There are many YouTube videos out there to look at.
Old Mar 8, 2021 | 02:01 PM
I disagree totally!!
Old Mar 8, 2021 | 02:13 PM
Technical Specs
  • MountingFront
  • Sight GlassNylon
So what happens when the car overheats with a rating of only 225*?
Old Mar 8, 2021 | 02:18 PM
That is a different glass(Sight Glass Nylon) for steam boilers. Just to give Joe a hard time. Respectfully!
rickw30
Jan 29, 2021 12:42 PM
Will22
Jan 30, 2020 07:44 AM
rpinnt
Feb 16, 2016 06:41 PM
wcourt3010
Apr 13, 2015 12:10 PM
oldspower_68
Mar 23, 2012 02:18 PM
