Clarification on 4-Core Harrison Radiator
Old Apr 5, 2018 | 08:42 PM
brock1030's Avatar
Did the “CH” tanks on the Harrison radiators make it into early 1970 production for the 442? I have a “CH” and an “IF” tanked 4-core for my auto with air 442 vert that was supposedly OEM to this car, which was built in early production for ‘70. Many though quote that the correct tank is a “CI” coded tank. Kindly advise on any wisdom. Thanks so much.
Old Apr 6, 2018 | 03:37 PM
Mr Shifty Sidney's Avatar
brock1030
The CH and IF tanks are for an "ED" coded 1970 radiator. The ED radiator was used in the 1970 442 series if it was equipped the Y72 option. This is the heavy duty cooling and generator package. If you look between the C & H on the passenger tank there should be a smaller letter embossed into tank. This is the date code (month) for the radiator. A= Jan, B= Feb.... The letter I was skipped. This may help prove if radiator is correct for your car. Also if my memory is correct the alternator should have a 2 groove pulley with Y72.
CI and IF tanks are for an "EC" coded 1970 radiator.
Hope this helps
​​​​​​​Don W
Old Apr 6, 2018 | 05:02 PM
70-442-W30's Avatar
344879M363895
Some pics to illustrate what Don mentioned above:
Old Apr 6, 2018 | 06:53 PM
brock1030's Avatar
[QUOTE=Mr Shifty Sidney;1087363]brock1030
Hope this helps
​​​​​​​Don W
Very helpful, Don. Thank you!
KZ442
Nov 29, 2019 01:54 PM
Vader
Nov 22, 2013 09:00 PM
L69
Apr 13, 2013 10:53 PM
815Cutlass1972
Oct 12, 2010 04:14 AM
