Changed the oil today on the new 65 cutlass
Old Oct 4, 2011 | 09:09 PM
kjr442's Avatar
Kjr442
I found that my 65 has a oil drain plug different then any I have seen, but this is my first car older then 69.
The drain plug looks like a torx style, maybe a t-70? but I was able to use a ratchet that fit in the hole along with a small pipe wrench on the outer edge. (Way Way to tight,and the filter was too!!)
So , is this the correct plug for this car?
Old Oct 5, 2011 | 02:12 AM
TK-65's Avatar
The drain plug looks like a torks style, maybe a t-70? but I was able to use a ratchet that fit in the hole along with a small pipe wrench on the outer edge. (Way Way to tight,and the filter was too!!)
yep.
Old Oct 5, 2011 | 05:06 AM
kjr442's Avatar
Kjr442
Originally Posted by TK-65
yep.
Thanks, Is this a torx? I do have a t-70 that was a little to loose,but could have worked if it was not so f ing tight.
Why would someone tighten this so much, and the filter too! I just don't get it!
Old Oct 5, 2011 | 05:34 AM
rocketraider's Avatar
Oldsdruid
Use a 1/2" drive ratchet ONLY without an extension. It should work fine. An extension usually slips in the splines and rounds them out.
There's a special 8-point tool especially designed for this drain plug but it's not commonly available anymore. Olds used this plug 1959-67, so it's not totally off the wall.
Old Oct 5, 2011 | 06:35 AM
jag1886's Avatar
I saw a special antique GM tool on EBAY a couple of months ago that was for removing the drain plug, I thought about buying it just because it was so oddball. 1/2 ratchet works perfect.
Old Oct 5, 2011 | 12:07 PM
slowolds's Avatar
Loose Radical
I would like to see that.
Old Oct 5, 2011 | 08:20 PM
2blu442's Avatar
Another Olds guy pointed out to me that in a 1965 A-body (probably '64 too) if you use the more common oil pan drain plug the bolt head will hang just below the front crossmember... so if you scrape going over a speed bump or anything else it's the drain plug that will be scraping
John
Old Oct 6, 2011 | 12:41 PM
kjr442's Avatar
Kjr442
John
I have seen that happen, but it was on a 1970 SS with a after market nine quart pan. After a hard launch it came down and turned the plug out of the pan.
MudEye
Apr 22, 2021 06:44 PM
TommyT
Sep 28, 2012 05:04 PM
1973olds98
Sep 26, 2009 01:59 PM
